Question about Cobra 29 LTD CB Radio
What would be a good size linear to add to a cobar 29 that has been peek and tuned and echo board put in it
  • 4 Answers
For a mobile or home base setup 100 - 250 watts is enough on all modes am / fm / ssb / cw, 1000w or 1 kw would be a overkill. what transmitters rely on is a tuned antenna and swr near 1:1 or 1:1.5, achieving a good tuned antenna will give you a clean output and good signal.
Posted on Jul 20, 2009
  • 141 Answers
No more that 500 watts max.
why?
Simple..anything over 500 watts wont be noticable to anyone close to you unless you go up to 1000 watts or more.
Posted on Jan 30, 2010
    President:
  • 1,348 Answers
1000 watts
Posted on Jul 17, 2009
Have connex board in my 29 sound tracker how should I set the board to the radio?
If you must use echo.. please use a dummy load. while adjusting the amount of echo.. you want it to be intelligible to the other listeners.. just barley add the echo effect and it should sound great and not like your in a can or all running together were no one can understand you...
Jan 01, 2016 | Connex Radio Communications
Hey guys i got a cobra 29 classic pushing a grey 150 bi linear the radio has been tuned and peaked and was told it was set to push amp fine however when i key up i get a humming noise what needs adjusting...
I suspect it is a ground issue it is hard to say. But I have lots of question. Is gauge wire large enough? Power source? Wires and coax laying across or parallel? If it has been peeked turn mic gain down and see if it helps. If you are using it with a external speak, key it away from speaker. Good luck give your radio man as much info as possible a good one will not want discouraged customer.
May 27, 2014 | Radio Communications
I have a cobra29 wx nw st. its been peaked and tuned, an echo board installed, and soundtracker override when i key up if my mic gain is over 1/4 the way up it makes an awful racket what do i do?
is there talk back installed? if so its probably too loud. You are getting feed back. The talk back should be low, just enough to hear it to check echo. 470 ohm resistor is perfect.
Jan 04, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
How do you tune and peak a cobra 29 ltd classic and how many watts will it put out after it is tunned and peaked
i would highly suggest you take it to a cb shop to get a cb tuned and peaked. before you do that though, make sure you have a good antenna system. a good antenna will have a much greater effect on your cb than tuning and peaking. as far as output, who knows? it all depends on the skill of the person doing the tuning. be warned that any output over 4 watts is illegal and you could recieve hefty fines if caught with an illegal radio.
Sep 23, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ltd classic side mic
First off I dont believe anyone to peek and tune but anyways. Make sure your mike is for the radio wiring. Next the guy that rigged it up might have gave you all the channels do all your knobs work??? usually you can tall as you get someone to talk with you a few blocks away and start, start turning and flipping switches till you can hear him most likely the guy that did the work on it messed it up. for a filter use a farite choke from radioshack on the mike wire.
Mar 17, 2009 | Cobra 29 LTD CB Radio
Scematic
Hi there!!
If you have an echo board what kind is it? I can give you the connections and where they go it just depends on which echo board you have!! I can also tell you where that talkback goes!! Let me know
Dennis
Dec 10, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Echo on cobra 29
When you purchase an echo board, the instructions come with them.
If you need any help, don't hesitate to email me at rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Aug 25, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Echo on a cobra 29 nw
Dean Pitts
Rollin CBs
Cobra 29 wx st
Take it back to your 'pro'. Let him fix it.
Jun 22, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
277 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
