Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Memory card my camcorder (sony DCR-HC42) has a slot for SD memory card. is it possible to use this card as a default for saving videos? thanks
    Scholar:
  • 80 Answers
The videos can only be stored in the Tape used. The Memory stick is used only for storing still pictures. No option of storing the videos in the Memory stick.
Posted on Aug 07, 2009
SOURCE:
Do i need a sd card o make camera work
You can't make the DCR-HC42 work with an SD card. This camcorder uses DV tapes, or Memory Stick Duo or Memory Stick Pro Duo memory cards.
Jun 06, 2012 | Sony Handycam DCR-HC42 Mini DV Digital...
What card in samsung smx-f40bn/xaa
FROM THE OWNERS MANUAL: Using a memory card (not supplied)
• This camcorder has a card slot for access to SD and SDHC (Secure Digital High Capacity).
• You can use SD and SDHC cards on your camcorder.
- Some cards are not compatible depending on a memory card manufacturer and memory
card type.
May 19, 2012 | Sony DCR-SX40 Camcorder
I have a DCR-HC42, when I connect it to my laptop thru Firewire (I have Vista). The size of the video is too high. How to download the video from the camcorder in a normal size.
Video downloaded from your camcorder is in .AVI format. One cassette size in AVI format is around 14 gb. Video cannot be downloaded in smaller size. After tranferring video to your computer, you can save or convert to any other format of smaller size eg mp4 or DivX or Xvid.
Jan 09, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
Transfer the video from my Mini DV to PC
If you have a dvd recorder, you can hook up the cam to a recorder if it has rca jacks on the end of the cable.
Or if your handycam has a memory card slot, record straight to memory card or transfer memory to memory card, then place it in a computer with an sd memory card slot.
May 17, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
Can I record movies onto my pro duo memory stick
In Sony DCR-DVD108, you can save only pictures in memory card.
Video movie can only be recorded on MiniDVD in camcorder.
Thanks.
Feb 19, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Transferring video to PC
Most of the time the camera has to be powered off then on again for the computer to pick it up. you can also try connecting it to a capture card and saving the files that way.
Also make sure there is no ! on the device itself and make sure all drivers are installed.
I am sure some of these tips will help thanks for using fixya!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
SONY camcorder DCR-HC42 color stripes
Try with the side display closed. Does the viewfinder show the pix OK? If so, then the problem is isolated to the LCD display. There is a small ribbon cable between the camera body and the LCD that sometimes gets a small crack in it. Replacing the cable usually fixes the problem.
Dan
Jul 10, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
151 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
