Question about Jabra BT350 Bluetooth Headset Headset
Did anyone figure out the pin number?
I have a Jabra bluetooth and no manual too!!! Does any1 have any clue what pin to use, is there more than 1, Help please!
  • 14 Answers
The default pin/pass key is 0000. hope this helps
Posted on Jul 17, 2009
How to pair jabra bt500v to a blackberry curve
Paring the JABRA head set to Mobile phone
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT500V.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank you
Sep 03, 2010 | Jabra BT500V Wireless Headset
All I can read on my bluetooth is that it is a Jabra. I don't have a user manual, I do have it paired with my phone but I don't know how to turn it off other then go to my tools in my phone and turning it...
You can not turn it off from mobile you need to turn it off using the key on the headset.Press and hold that button for about 4 seconds it will switch off.
To pair the headset follow below instructions
3. Search for Bluetooth devices and select Jabra BT2070.
Thank you
Aug 31, 2010 | Jabra BT350 Bluetooth Headset Headset
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
Can't connect
In your Jabra bluetooth headset, press and hold the button in the headset until you see BLUE flashing light. Once the light is flashing in the Jabra, go to your Motorola phone and search for any Bluetooth device in range. when the Jabra shows up, select the Jabra and put in the pin code for the headset "its either 0000 or 1234)
Cheers!
Jun 10, 2009 | Jabra Bluetooth Headset with Adjustable...
Pin Number..,Where do I find the pin number for my Jabra A320S CD-ROM download?
for installation if it asks for pin turn around the cd cover and in bar code sticker u ll find it to connect to the mobile or to bluetooth devices for eg: if u enter 0000 in in ur computer same to be entered in the mobile and u will be paired to the device and u ll be able to use it
Nov 02, 2008 | Jabra A320s Bluetooth Wireless Adapter
I couldn't get it to pair this morning
From the manual )link below),,,, 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press and hold the answer/end button until a solid blue light comes on. 2. Set your Bluetooth phone to ?discover? the Jabra BT350 Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* (See example from a typical mobile phone in fig. 5) 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Jul 28, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT500
the pin number is 0000, press and hold button until the light stays on to pair with your phone.
Jun 04, 2007 | Jabra BT500 Wireless Headset
Jabra BT350 Bluetooth Headset Headset Logo
208 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
