Question about Safety 1st Designer 22-325
How do reassemble my car seat i made a mistake and cleaned and washed the cover and i do not know how the seat belts go back on the car seat help please
jc2it
  • 58 Answers
SOURCE: reassembly
Dorel Juvenile Group manufactures these car seats for under the Cosco brand. You should check out their web site.
  • Check out the recall notices and make sure your seat is not listed.
  • Register your car seat so that you are informed of any future recalls.
There does not seem to be any Manuals on their website, but they do list a phone number. 1-800-544-1108
Good Luck!
Posted on Nov 16, 2007
SOURCE: Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Posted on Sep 27, 2008
  • 20 Answers
SOURCE: Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
Posted on May 08, 2009
lingIT
  • 105 Answers
SOURCE: how do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
Posted on May 16, 2009
  • 6 Answers
SOURCE: need to put car seat cove back on
This can be very tricky! Usually, you must put on the cover first, then guide the belt through the openings from the front. Turn the metal retainer clips sideways, and then anchor them on the back of the seat. I used to have one of these seats, sorry I do not still have the manual though. You can also try going to the company website for advice. Good luck.
Posted on May 20, 2009
I have a Edinburgh delux booster car seat. I needed to wash the cover and unbuckled everything and now I don't know how to put it all back together. Please help me I've tried googling the seat
Contact a certified Child Passenger Safety Technician (or equivalent if you are not in the USA). www.nhtsa.gov
It MUST be reassembled correctly. Do not guess!
Apr 11, 2013 | Baby Gear
Need to reassemble belt system
http://www.coscojuvenile.com/usa/eng/Instructions?ProductNumber=22216LLP
Just need to enter manufacture date to get the manual.. The instructions should be in there to reassemble the belt system..
Jul 11, 2010 | Cosco Juvenile Scenera Convertible Car...
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Belt on my Whirlpool dryer brokeModel # LE 5780XKNO.
Remove the back cover.
Remove the belt and drum.
Place the new belt around the drum and sticky tape it to the position of where the old belt was seated.
Insert the drum back into the cabinet of the dryer and reconnect it to the electric motor.
After connected to the motor, remove the sticky tap and reassemble.
Job done.
Jun 17, 2009 | Dryers
Need to clean carseat al eddie bauer online manuals aren't availa
First, snap out the black pieces that attach the cover to the seat with a pair of pliers or a kitchen knife. Then turn the seat over and remove the base by sliding out the metal rod that runs thru the base and seat. Then unhook the center buckle from the bottom of the seat and back up thru the seat. Unhook the straps from the metal bar on the back of the seat and thread them back thru the seat. Be sure to remember the order in which you slide it thru the components so you can reassemble. It may be helpful to lay them out in the order you removed them. Unhook the elastic bands holding the bottom in place and slide it over the top part of the seat and off the seat. If you need to remove the top part and wash, remove the black pieces the same way as the bottom, unhook all elastic and slip it off the top. I wash mine in cold water with mild detergent and usually let it air dry so as to not shrink it. Reassemble by reversing steps.
Jun 06, 2009 | Eddie Bauer 3-In-1 with Latch
May 08, 2009 | Century Encore 5-point Harness
No solution or water coming out...
the water out let are pluged the machine sits dormant with soap in gravity pulls it down and the heat drys it. thus on h2o now to fix it turn up side down remove screws from bottem plate and belt assembly turn back over lay handle on floor remove scews from middle front and back use long blade screw driver remove cover with cellphone take pic of vac with cover off [ for reference on reassembly] water head located on the front of vac pull head and hose from seat wash with hottest water you can stand try to blow air through it with your mouth .with cover off put water tank in plug in vac careful not **** any thing up turn on vac try the water if no try pump check hose connector. To reassemble reverse steps using pic as refenece this should help later
Apr 01, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Putting the belts back together again.
NOT REALLY A SOLUTION BUT THE BUCKLE HAS NOW BROKEN SO WE WILL BE BUYING A NEW CAR SEAT NOW!
May 06, 2008 | Britax Baby Gear
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Safety 1st Designer 22-325 Logo
319 people viewed this question
Top Safety 1st Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
