Question about Karcher Garden
Karcher ran out of diesel and now does not heat the water
    Sergeant:
  • 384 Answers
Buy more diesel.
Posted on Jul 17, 2009
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
May 21, 2015 | Karcher 3000 PSI Gas Pressure Washer with...
I have lost the pressure of water but the motor is still working.
If the motor was ran without the water being attached to the washer it would crack the pistons which is what creates the water pressure for you.
Aug 18, 2012 | Karcher K 391m Pressure Washer
My electric Karcher pressure washer does not shut off.
this can be that you need to bleed the system of air or that there is a problem with your trigger gun sticking when you release the trigger.
These are two things I would check before you go into the machine.
May 14, 2012 | Karcher Garden
My Kärcher K2.080 pressure cleaner (1450psi /
According to my search, Karcher has a 2 year warranty on this product. If you can get the serial number and model number off of it. They should be able to identify when it was made and then can honor that warranty. Otherwise the pump seals appear to be damaged by your description of the problem. Hope I've helped.
Best, Mark
Dec 28, 2010 | Karcher Electric Cold Water Pressure...
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Was using Karcher and then suddenly no pressure. Motor seemed hot
not sure about this model but some of them had mototrs that ran constantly wether the trigger was squeezed or not.
on these models there was a pressure relief valve just inside the water hose inlet connection which have been know to work loose.
if not the above type the discount the relief valve
the water pump usually comprises of 3 pistons and various valve assemblys you would need to take the pump apart and check theses parts some had three large nuts that contain the valves .
hope this info is of some use to you
Apr 04, 2010 | Karcher K2.26 Electric Power Washer
I have a Karcher 3000 model G3060 OH WITH hONDA G190
It may be due to some water getting into the engine. I would change the gas and change the oil.
Sep 10, 2009 | Karcher G3025OH Pressure Washer
Karcher hd 5 11/c pressure washer no pressure
Your problem is simply a worn bypass valve on its awy out. It still works enough for mains pressure but can not pressurise when drawing water.
Jan 14, 2009 | Karcher K2.26 Electric Power Washer
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
262 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
