Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Transferring video to PC
I do have a sony camcorder model DCR-HC42 but i cannot transfer to my PC.i have a USB connector but it doesn't detect on my PC. thanks.
  • Sony Master
  • 3,866 Answers
Most of the time the camera has to be powered off then on again for the computer to pick it up. you can also try connecting it to a capture card and saving the files that way.
Also make sure there is no ! on the device itself and make sure all drivers are installed.
I am sure some of these tips will help thanks for using fixya!
Posted on Jul 17, 2009
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Cannot capture video
Option 1:
(Applicable for Windows XP Operating System only):
As you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 2:
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!!!!!
Sep 23, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
UNABLE TO TRANSFER VIDEO FROM SONY HANDYCAM DCR TRV TO MY LAPTOP
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Sep 11, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Where can get the sony handycam DCR-HC42 device drivers support Windows vista
Aug 31, 2009 | Sony Handycam DCR-HC42E Mini DV Digital...
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Jun 07, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
My computer is not able to detect my handycam
Please go to camera menu > settings and enable USB stream option so Windows will detect / recognize your camcorder.
Let me know if this not works to help you out.
Please intimate what Windows you are running in your PC?
Feb 14, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony digital handycam dcr-trv33: how to transfer video to computer
first you need a driver for your camcorder to recognize the device what you plug. use USB for pluging it. upload your videos to any movie maker application such as ulead movie maker, nero movie maker, windows movie maker, etc.. save it with any various types of videos like avi, divx, vcd, dvd, etc.. and now its on your computer. heres the link and other instructions of installations. hope that helps!
http://www.sony-asia.com/support/download/1656/product/dcr-hc42/modelfirst?site=hp_en_AP_i&subpage=detail
just click the download bar
CHARCOIS
Aug 26, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Transfer
i think only way is to use iLink cable to transfer videos
Aug 11, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam dcr-trv19e
sir, i need driver software for transver my handycam to pc. my handy is sony dcr trv19e
Nov 27, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
259 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
