Question about Samsung SGH-d807 Cellular Phone
Charging port connector
The charging port connector on the side of the phone has a piece broken off inside and the two end wire connections are no longer in place. The result is that the battery will no longer charge. Is the connector available seperately or should I try to find one these phones dead to get replacement parts?
  • jmahalovich Nov 23, 2007
    My phone went out around the same time yours did. I thought it was the battery until I saw this. It makes perfect since that my battery wouldn't work because the connector is messed up. I have even bought a replacement battery and it doesn't work. Have you found a solution?
You can get it fixed at a place in Los Angeles Tel: 323-651-5555
Posted on Nov 24, 2007
The charger usb port is there any other way to charge unit
Yes there is, buit it depends if your device supports this methiod. Its called "Wireless Charging". It is a simple as placing your device on a pad that is connected to a power source. You can buy these wireless chargers at places like Best Buy or The Source.
Dec 31, 2015 | Cell Phones
Hisense sero 7 lite
check wires....if it's not broken or damaged.....
check if cable is not broken around connector area or around plug...
check if you connected connector deep enough while charging..... check if connector on tablet is clean, if not, try to clean it, remove dust from inside
Jan 13, 2014 | Tablets & eReaders
My son cut the wires to the rearvew miror and now has no electric sunroof, windows, or central locking
Sorry to hear this has happened to you, hopefully your son didn't get hurt.
Hopefully you can see and reach both ends of the wires he cut so you can see the wires clearly (if it's hard to see, get a flashlight).
Disconnect the battery.
You need to get barrel connectors, wire strippers and a crimper.
Here's the barrel connector:****-Connector-4X313?Pid=search
Here's the crimper/wire stripper combination tool:
If you look inside the connector, you will see a piece of metal. This piece of metal will act as a "bridge" for the electricity. The crimper will squish the metal to the wire (metal to metal contact). The crimper has a color code dot in the front of the tool's mouth to show you where the barrel connector needs to go. The mouth has two places to crimp and the correct spot needs to be used to crimp correctly.
Go one by one in the crimping process so you can make sure you get this correct and not cross wire anything. Each wire has a specific color code so one end of the cut should match another end of the cut (make sure you look closely at the wire's insulation because sometimes there may be two colors on the wire's insulation). Everything should be ok as long as you pay close attention to the color codes and crimp properly.
Once you find each end of the cut wire, remove a quarter of an inch of insulation on both sides using the stripping holes found inside the crimper's handle (the quarter inch of wire should show bare metal). Take a connector and place the exposed wire into the connector (take a quick peak to make sure the wire is inside the metal tube), then take the crimper and squeeze the crimper as hard as you can where the wire and metal barrel meet. You should be able to pull on the connector without the wire coming loose. Now place the other end of the wire into the opposite side of the connector and squeeze again. Give it a tug to make sure it is on.
That's it - repeat as many times as necessary to get the ends "bridged." Once you're done, connect the battery and give it a test. You should be good to go. It's a long explanation but this is really easy to do, once you see the connector and crimper this explanation will make more sense to you.
Jan 03, 2011 | 1993 BMW 3 Series
I cannot connect to pcsuite its displays to be disconnected
Hi Piyush,
The problem seems to be with your USB port on either end. If you use your USB port (PC end) rarely then there's a chance of corrosion/oxidization that has formed on the contacts. Use a little bit of WD40. First take a small piece of good thick drawing paper (the ones used by kids in class to draw stuff on).
Fold it in such a way so as to fit it inside the PC's USB port. Now apply a few drops of WD40 oil on the paper's folded edge and insert the paper gently into the port and rub it (IN-OUT-IN-OUT) action. Now try connecting your cable & handset.
Assuming that you have a frint panel USB connector and if its still not working then there could be a loose contact problem with the 4 pin USB motherboard connectors. Switch OFF the PC, remove the side cover and see where the wires go on the motherboard from the front panel.
Remove the pins one by one, apply a little WD40 in the sockets of the black, square cylindrical sockets and place them back and restart your PC.
It should work now.
Nov 06, 2010 | Computers & Internet
My guitar hero world tour drum kit is broken
If you know how to solder, you can resolder the wire back onto the connector. I just did that tonight actually. the orange cymbal has a white wire and a black/bare copper wire. You can cut open the male connector [I use an exact-o knife along the underside mold line] (one side only) so you can just slide the wires/connector back into it. The white would solder onto the base of the male connector. The bare copper thats wrapped around the white one is the black/bare copper wire mentioned above. This one is soldered to the tip [the solder point inside that small black plastic piece] of the connector. Once you have it soldered, just slip the male connector rubber piece back into place and use some super glue to glue back together.I wrap it in electrical tape just so its definitely secured. If wire length is an issue, simply solder some wire extensions before soldering to the male connector/plug.
Mar 22, 2009 | Nintendo Activsion Guitar Hero® World Tour...
Assembling the play and charge kit
The wire piece connects to the top of the controller. Align it so the light is on the front, and press straight down until it snaps into place. Connect the other (smaller) end to your console.
Jan 10, 2009 | Microsoft Xbox 360 Wireless Controller and...
LG scoop not charging well
The problem is your charge port on the phone. I've already had to have mine replaced and my daughters due to this issue. My girlfriends son had this phone to and has had his replaced twice already.
It is not entirely the charger! The problem is the phone port. The rep at alltel told me this phone is the most problematic phone they sell due to this issue!
Have the phone replaced under warranty if its under a year old, otherwise hope you have your insurance!
Other things to consider before having it replaced:
Backup your contact list! They cannot transfer it for you to the new phone when the port is bad and you cannot save your contacts to an SDcard either.
If you have any music, pictures etc, get the microSD card and back them all up to that so that you don't lose them either. Just don't buy the card from alltel, they want twice as much for it as you can get it for from Walmart/BestBuy etc..
Hope this help any of you out here from experiencing the pains that I've gone through with it..
Jun 14, 2008 | LG VX8300 Cellular Phone
Lg prob
it is better way if you have warranty then make use of it ...
if not if you are good at opening then open it and just have a look near port ... if you have the broken piece join it by soldering...
if you dont have that broken piece then just take two small wires an d carefully identify the positive and negative in the circuit board & solder it near the port which is used for charging and then cut the pin of the charger and connect the positive & negative correctly to those wires whenever you want to charge ....
else visit the technician he will replace if the spare part of it is available ..
this doesnot charge too much it is affordable so i suggest you to visit the technician....
Apr 15, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Cable Connector inside TV
Unless you know how to sholder well and know how to do an isolation test on the set after its repaired I would let a pro do it My friend as I've seen it a hundred times. A peep will simply hook up a connector to the set and ground the connector or what looks like a ground and as soon as that set is pluged into an ac outlet and a cable or sat line is attached KAPOWWWWEEYYY.. It smokes and you end up blowing out the bridge rectifiers aong with all sorts of things. Now dont get me wrong please as you can repair set if and only if you wanna take that chance by simply taking a piece of coax cable with a connector on one end and soldering the center wire onto the broken wire that came off the connector and then soldering the outside or sheild wire to the place where the broken connector was attached if at all possible BUT I repeat this is not a good way to do this. Good luck
Mar 23, 2006 | Sanyo DS31590 31" TV
Samsung SGH-d807 Cellular Phone Logo
76 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
