Question about Gateway FPD2275W LCD Monitor
GATEWAY 2275 LCD MONITOR WENT OUT, WHEN PLUGGED
GATEWAY 2100 LCD MONITOR WENT OUT, WHEN PLUGGED IN, BLUE [PWER LIGHT COMES ON FOR 1 SEC THEN GOES OUT, THEN BLINKS ONCE AND GOES OUT AGAIN. NO OTHER ACTIVITY FROM MONITOR AFTER THAT.
NOTE: IF MONITOR IS LEFT UNPLUGGED FOR 30 MIN, THE SAME SEQUENCE WILL OCCUR WHEN POWER CABLE IS PLUGGED IN.
  • Gateway Master
  • 3,866 Answers
This could be due to a bad power supply inside the monitor witch is replaceable for like $25 bucks all you got to do is unscrew off the back undo a few cables and put in the new supply.
I hope this helps you in the repaire process if its under warrenty please seek warrenty guidlines.
Posted on Jul 17, 2009
It powers on and then off in sec.
I think your OS or some hardware are bad. Post more info.
Oct 02, 2014 | Gateway Fpd2185w 21" Widescreen Lcd...
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
FPD2275w monitor monitor powers on but shuts off after 1 sec shows a picture perfect before it goes black all buttons light up and stay lit sounds like they r working
This model will likely have 2 or 3 bad capacitors in the power supply. You can see the tops bulging. They are 1000Uf @ 10 volts.
Monitor Mike
Aug 20, 2010 | Gateway FPD2275W LCD Monitor
Monitor is black...checked all connections..OK. Turned computer off and back on,still no screen. HELP!!!
The first thing I would do if possible is hook up another monitor to the computer to see if that one works. If it does, then your monitor has gone bad. If it doesn't work either, then your video card has gone bad. Did you hear any beeps when you started up your computer? If you did, then this usually means there is something wrong with the video card. Also, sometimes the power button is turned off. Are there any lights lit at all on the monitor and are they green or yellow?
Aug 18, 2009 | Gateway FPD2275W LCD Monitor
The on off button on front doesn?t turn the unit off and on
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
Jul 03, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
Screen only stays on for 1 sec
Assuming you changed all the caps and did it correctly.
IF you get flickering, It could be a transistor on the inverter board.
OR !!! and probably more likely,
It could be one of the bulbs in the lcd itself is failing. It only takes one bad bulb to stop an inverter from firing up !! You can check them one at a time if you have another working monitor.
If you do unplug a good bulb from the good monitor and try each of the questionable ones, one at a time.
Doesn't have to be a gateway monitor to test it, just needs the same backlight plug.
ebays bammbammfran
Jun 05, 2008 | Gateway FPD2185W 21 in. LCD Television
Monitor problem
You need to figure out if the monitor is faulty or if it is due to the power in your house (not likely) or the fault of the computer.
  1. Try the monitor on other power jacks.
  2. Try the computer on other monitors and see if you get the same response.
If it seems to just be the monitor then you will most likely have to have it serviced or replaced. Is it still under warranty?
May 13, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
685 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
