Question about Garden
How do I know the chain is on the correct way?
The chain has been cleaned and sharpened. I have put the chain back on the saw, but how will I know it is on the correct way?
  • 76 Answers
Hi
if the chain is in the right way and has been shrpen belive me you will know once you cut some wood.
just make sure the chain is in the right way
see the link
http://www.ehow.com/video_4419336_replace-chainsaw-chain.html
good luck
Posted on Jul 17, 2009
Chain saw sharpening angle
For cross cutting is 30 degrees and if you only do ripping it is 10 degrees.
Apr 22, 2015 | Poulan 16" 38cc Gas Chain Saw P3816
Best way to sharpen ms 250 c stihl chain
I can't show you pictures but I can try to explain. Tighten the chain on the saw to the normal working tension. If possible put your saw in a vice with the vice jaws clamped on the bar in a way that allows free movement of the chain around the bar when the chain brake is off. work your way around the chain to find the shortest tooth on the chain. Sharpen that tooth by using a file (4.8mm for the normal chain on that saw). You should work at 30 degrees across the face of the tooth.The spec says you should also angle the sharpening at 5 degrees from horizontal but if you have the chain at normal tension then the movement of the chain in the bar while sharpening is likely to give you about 5 degrees anyway - so just work horizontally and you won't have a problem. You only need gentle pressure pressing back towards the engine of the saw and enough strokes to get the surface of the tooth free of any pits, chips and rounded edges. When finished mark that tooth - I use a felt pen so it is easy to see. Do the same for every other tooth but to ensure the saw cuts straight (and does not give you curved cuts) it is essential that every tooth is sharpened to the same size as the shortest (use a measuring gauge if necessary). When you have been all the way round on all teeth then you need to adjust the depth gauges on the chain links. If you don't then the saw will probably only produce fine dust and not nice cut wood chips. With a flat file and depth gauge tool place the tool along the teeth pulled back against one. Through the gauge fingers you will see the chain depth limiter and this needs to be filed down to the level of the gauge tool. If you start the process at the tooth you marked earlier you will easily see when you have worked all the way around. Your chain should now be sharp. Before using it it is advisable to remove the chain from the saw and clean any filings out of the chain and bar to avoid them causing unnecessary wear. Good luck.
Sep 11, 2014 | Stihl Garden
I have a Craftsman 3.5 hp 16" Electric Chain Saw that I haven't used in year. Are their key steps to clean-it up operationally before I use it or start it?
Kcbriangerli:
I would first clean the saw... especially the chain drive area (remove the cover first and use compressed air if you have a compressor). Check the drive sprocket for excessive wear. Check the power cord for any damage. pull up on the chain at the middle of the bar to ensure the chain is not too loose or too tight (the chain should be able to be pulled up one eighth of an inch... no more. None of the dogs at the inside of the chain should come completely out of the slot in the bar. If the chain is too loose, adjust it by reinstalling the cover, ( When you put the cover on, make sure that the small nib on the chain tensioner fits in the small hole in the bar). loosen the two chain bar retention nuts and adjust the screw at the front of the main body next to the bar. When the adjustment is correct, tighten the chain bar retention nuts and check the chain tension again. If you have a chain sharpener, now would be a dandy time to sharpen your chain.
Jan 20, 2013 | Craftsman 16" Electric Chainsaw Chain Saw...
I sharpend my chain and filed and flip the bar around. And it still want cut. Do I need a new bar and chain?
I dont me to be rude but two things spring to mind, firstly have you put the chain on backwards? the chain on the top of the bat should have the sharp edge facing away from the saw ( turns clockwise as you look at it from the side of the saw ) and secondly have you sharpened it correctly ( right angles, and taken the depth gauges down to the correct hight ) there should be no need to replace the guide bar, at worst a new chain will do, let me know if you need to know more about chain sharpening.
Feb 16, 2012 | Garden
We have a model 137 chain saw. I need to know what size file to sharpen the chain and the correct angles for this model.
all saw blades are sharpened to the same angle. 37° the file size you are going ot want is 1/4-3/16in.
Apr 18, 2011 | Husqvarna Garden
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
I'm a girl. remington electric chain saw not cutting. chain seems loose, was out of lubricating fluid, added more, still won't cut. how can i fix it? or do i need to sharpen it and how?
Yes you need to "have" the blade sharpened. I emphasize "have" for if you've never done one it is virtually impossible for me to insruct you from here. It doesn't cost much to get them sharpened. Also make sure the guy tells you what direction to put the chain back on. Thank you, Dana
Mar 26, 2010 | Remington Electric Chain Saw
I need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Aug 19, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
My first chainsaw...am seeking general advice on product use etc
Ok to get correct tension on chain, basically loosen it a little until the chain on the underside of the bar is hanging a little... Now start tightening it up again. Basically you want the chain (the main part of each link) to be just touching the the underside of the bar. This will give correct tension... Note that chain does expand as it heats up so it may loose tension... so this is perhaps best done when the saw and chain has warmed a little. Also, new chain will stretch a little naturally so check tension each tme you use the saw.
If you do not know hoe to sharpen a chain properly, it is best to get someone else to sharpen it, or buy a new chain... Eventually all chains will need to be replaced because they can only be sharpened so many times before the cutting teeth become too small to work effectively or safely.
As for oil, if it is an electric chain saw, you only need chain/bar oil. Any good name branded bar/chain oil designed for chainsaws will work well.
Please rate my solution on FixYa!
Thanks.
Apr 01, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
