Question about Microsoft Xbox Console
My xbox 360 disk drive want open or colse - Microsoft Xbox Console
  • 767 Answers
The drive motor is a little weak
and the magnet that clamps the cd in
place is to strong .
To find this out slap the to as you press
the Eject button .If that works you need a
new drive motor. I use to put a few layers of
masking on the top hub to weaken the grip
of the magnet , and that seem to work.
Posted on Jul 18, 2009
XBOX 360 READS "OPEN TRAY"
common problem with your disk drive you need to clear your cache to do this go to system setting then memory then hover over your hard drive then click y then click clear system cache
Dec 23, 2010 | Microsoft HOP-141X laser lens for Xbox 360...
Sprayed xbox with cleaner now only says open tray
It sounds like you have blown air into your disk drive, doing this spreads the dust which can end up over the lens, try a cd cleaning disk, this should remove any dust that has settled on the lens.
Jun 27, 2010 | Microsoft Xbox 360 Console
Xbox 360
Most likely your disk or dvd drive is dirty. Run the disk through a disk cleaner and run a dvd cleaning disk through your drive.
If that dos not work, try removeing disk, close drive, turn off console, unplug power supply, wait 10 or 20 seconds, then reconnect power supply and try again.
If that fails, assumeing other disks will read, your disk may have a major flaw. You can check with your local game store, they often have a machine that may restore your disk, (most places that I know of charge like 1 or 2 $).
Mar 10, 2010 | Microsoft Xbox 360 Console
Xbox 360 will not read a disk. It says
It's a loose cable. Strip down your xbox 360 until you can see your DVD drive. Then replug all cables. It should work again. Otherwise it may be the lens.
Feb 01, 2010 | Microsoft Xbox 360 Console
Xbox 360 disc reading problem
these are solution
clean the optical cd
or maybe that cd is corrupted
your disk or xbox 360 is damaged....try repair a disk drive..
Nov 26, 2009 | Microsoft Xbox 360 Console
My xbox 360s isn't working
In very rare instances I believe that the dvd drive of your xbox 360 might have been disconnected.In this case,it dispays an "open tray" message.For this you will have to open your 360 but please take it to the dealer if you are still protected by warranty.Good luck.Thanks for reading.
Jun 18, 2009 | Microsoft Xbox 360 Console
Re: Blinking green light/won't detect disk drive
If you still have a warrenty sticker call up Microsoft and tell them that your Xbox 360 has overheated, and tell them your serial code. They will tell you if your warrenty is expired, if it's not they will ask you where you live then pick up your Xbox 360 and fix it for free. If your warrenty has expired try this. Power off the Xbox 360 and when it is off press the eject button, it might open they tray. Or try opening your Xbox 360 and remove the disk drives cables from the disk drive and the motherboard and put it back together, you should never try the towel trick really, although it works it can also give your Xbox 360 3 red lights then you have to buy X-clamps and theormo paste, just do the X-clamps and theormo paste when you get one red light. I have had two Xbox 360's, when I did the towel trick it burnt the GPU, the other one a little componante came loose, sorry for my spelling. Hope this helps =D
May 25, 2009 | Microsoft Xbox 360 Pro System Console
the sata cable sliped from the dvd drive (if under warranty send it back) if not open yourself and plug it back it
May 22, 2009 | Microsoft Xbox 360 Pro System Console
My xbox 360 won't read my disks
if it does this with all the disks then your drive is either 1.drive is bad 2.firmware is corrupt. i would assume that your drive is bad, unless you have tried to hack your drive firmware and corrupted it. if you did try and hack the drive send me an email at nelsontimmy@hotmail.com and i can tell you how to reverse it.
Apr 17, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
79 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
