Question about Dell (E210882) Motherboard
I have the same problem
I plug the PS to mainboard just small green light s on no power appearently to other parts of mother board wat should i do? :(
    President:
  • 1,179 Answers
Did you plug in both the main psu plug, 20 or 20+4 plug and the 4 or 8 pin plug? The main is usually near the front of the motherboard and the 4 or 8 is near the cpu socket. Both must be connected in order to supply power to the board. Hope this helps.
Posted on Jul 17, 2009
Please help me. Am having HP desktop computer. When I plug in the power cable the green light on the board switch meaning the board and the power pack are working but when I press the switch key the...
Open the side of the case and look look for a led on the mainboard. It should be on if the power supply is working properly. Have any changes been made inside the computer such as a new video card or harddrive? Perhaps the connector for the power switch has either come of the mother board or has failed.
Jan 26, 2015 | HP Computers & Internet
Relay clicks when applying power. Yellow light comes on. TV is dead otherwise. Power supply is outputting +5, 12, and 24 volts Mainboard (3647-0282-0150) has +5 and 12 volts always applied. Checked...
Amber light on means standby voltage is high. IF amber light does not go white when power button is pushed the its one of two things.
A. No power on command from main board. Usually labeled PS-On. Should go high from 3.3v or maybe 5volts. If not present Main is defective.
B. If the ps-on line is going high then your problem is a defective power supply.
Oct 15, 2013 | Vizio XVT472SV 47 in. HD-Ready LCD TV
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
I had a power outage and my computer when I tried to turn it back on after the power was turned back on. All it does is have a green light blink on the back of the tower and a small green light on the...
most likely the surge fried one of your ram chips... this is where i would start first sometimes the ram will work as a surge protection for your motherboard
Nov 18, 2010 | Computers & Internet
I have a Dell Latitude D610. The battery was dead (got the 4 blinking amber lights and the green light flashing once, then cycling), so I replaced the battery. The new battery has the lights on the bottom...
From the description, sounds like you have two failures, both concerning the mother board.
1. The connection to the motherboard for the battery is no longer good. Replace the mother board. The points of failure that you have given so far and has not fixed the issue. Battery fully charged, seated well, no change, mother board.
2. Laptop will come on with AC adapter attached but will not boot up; mother board. There is a built in test that you can run, from a powered down state press FN + Power button, this puts this into a diagnostic state. If it does not go into this diagnostic; mother board. The diagnostic is stored in the BIOS, which is a part of the mother board.
3. If the diagnostic runs note any error codes that it gives. They will be in the form off XXXX-XXXX or XXXX:XXXX, where the X's represent a letter or a number. These can be used for further trouble shooting.
Jul 24, 2010 | Dell Latitude D610 Notebook
The monitor led is green but it gives white flash and still blank
Check the volatage regulator in the mainboard resolder all you found dried unsolder parts inside mainboard. Voltage test the regulator IC if have a voltage flow 2.5 to 5v DC. check ribbon cable connector from mainboard to controller board if properly connected. In the controller board find the small fuse test it for open.
Reminder:
When you voltage test in the power board
in the primary section of power supply
use hot ground. Do not use the hot ground
when you voltage testing the secondary
power supply, mainboard and controller
because it will cause of damage
semiconductor. For safety use cold ground
for secondary, mainboard and controller
board.
Aug 29, 2009 | ViewSonic VA712 17" LCD Monitor
I have a computer with an Intel D845GEBu2/D845PESV mother board. One day works great, next day no longer powers up. I changed out the PS, all I get is a small green light on the mo bd that lights up...
If all you get is a green light, and no fans, hard drive spin up, nothing on the monitor, well than, it could be that the power supply is the wrong one for your computer. Either that or the motherboard is shot.
double check on the power supply, that is probably the problem.
Aug 05, 2009 | Intel Computers & Internet
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
ASUS p4s533 will not start
Your motherboard is bad and will need to be replaced.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 08, 2008 | ASUS P4S533 Motherboard
No power no light
Could be either one, or it could be the toggle switch.
Start with the easiest first to check. Unplug the power toggle switch from the mainboard and take a screwdriver or something and short out those two pins to see if it starts the pc. if it does, then your pc case switch is just bad.
If that's not the problem, check the power supply next.
Jumper the ATX 20 pin power cable's green wire to any black, just to make sure the power supply is working. The fans in the power supply will turn on along with anything else hooked up.
To jumper the power supply use a section of wire or a bread twisty (with the insulation removed from the ends) and just connect the green wire to any black wire on the 20 / 24 pin power connector. Make sure that the power switch on the back of the power supply is switched on.
If neither of those seem to be the problem, then most likely it is the motherboard or the processor.
Dec 21, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell (E210882) Motherboard Logo
206 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
