Question about Efficient Networks SpeedStream 5871 Router
Unable to delete route from Efficient Networks 5851 Router
I can't seem to find how to add or remove a default route from this type of router. There doesn't appear to be any documentation online for this device that explains how to add/remove routes. Unfortunately the commands are nothing like cisco IOS so i'm stuck
typing "iproutes" shows the route and typing "eth ip addroute" does nothing for me.
any help/suggestions to fix this issue (aside from replacing this crappy equipment) would be much appreciated.
thanks!
    Scholar:
  • 101 Answers
Sorry to suggest this but since they don't make that unit any longer, it would be simplest to just replace it. The command set is not for the novice and you are correct nothing like Cisco IOS, you can still download the manual from http://www.infobro.com/anon-FTP/Security/5800URG.pdf
If I recall correctly, the default gateway is your default route on these units, been a few years since I have seen one.
Posted on Jul 23, 2009
How do i find the wep key on the 6520 router
Login using username and password->click "Wireless Security" and Select "WEP" as the security encryption type.
Set the default transmit key to "1."
Type in a passphrase and click "Generate". This generates random passkeys.
You can note down your network's SSID (listed on the security page) and the first WEP key.
Aug 26, 2012 | Siemens Efficient Networks SpeedStream...
Router ar 410, wan port is eth0 with statick ip, public, and switch port 1 is on vlan2 with pirvate ip address 192.168.18.253. how tu add default route for acces to internet eth0 is connected on shdsl...
Does the DSL router have a model number? Also for the public address, can you give me the first couple of digits. I just want to make sure it is truly a public IP address and not a class A or B private address because only an ISP can hand out public addresses.
If the IP address on eth0 is indeed private, I am guessing you have to get into the DSL router and set a static route to point to let it know about both of the the ar410 networks on each interface. Keep in mind it might not understand VLSM so when you static route in the DSL to the 192 network you will only need to specify it as 192.168.18.0 as class C default mask is 24.
Mar 01, 2011 | Allied Telesyn AT AR410 Router
Systempassword change required for siemens Gigaset 504AU
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on system menu and change admin password then save settings and restart router Let me know if you need further assistance. Thanks for using FixYa.
Sep 08, 2010 | Siemens Efficient Networks SpeedStream...
Default ip for siemens 504 agu
Do this... run connect to it with a network cable, The follow along.
START >> Run >> type in "CMD" with no quotes then at the black box enter "ipconfig" omit the quotes look at the gateway address as this will be your routers IP
Aug 27, 2010 | Siemens Efficient Networks SpeedStream...
How do I reset my siemens 5940 router to factory default
one of button their in your router you can press upto 20 sec or you can login in your router with help of your PC or laptop and then you can also reset your router with help of menu.
Mar 30, 2010 | Efficient Networks Siemens Se5940 T1...
What is the routers address for configeration
192.168.254.254 is the default IP address of Efficient Networks Speedstream 2623 router.
Default password to login is 'admin'.
Oct 12, 2009 | Siemens Efficient Networks SpeedStream...
RJ45 Pin Out
That is very difficult to describe in just text, but here is a link to a diagram with the pin out information for you:
http://www.markatindustries.com/ kcs_overview_works_66_pinout.asp
Take out the space, for some reason the text / chat system doesn't allow most web addresses, so just erase the space after the last /
Thanks!
Jul 07, 2009 | Efficient Networks SpeedStream 5851 Router
Acer with Windows Vista does not connect to Internet
You're laptop needs to have a profile for the router. Go to Network and Sharing Center, Manage Wireless Networks. Please remove all the listed networks there. Now click on Add, then Add a Network in Range of this Computer. Select the wireless name of your router and connect. If it asks for a network key, please type your wireless security key then connect. That should do it.
Dec 19, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Access to 5260 model
Hi, ya may wanna try 10.1.1.1 or 192.168.0.1 as these are two alternate Ahem "Default" settings. I also found this linkhttp://www.dslreports.com/faq/efficient That may help ya sort ya problems out.
Aug 09, 2007 | Efficient Networks SpeedStream 5260...
Efficient Networks SpeedStream 5871 Router Logo
164 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
