Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
My Kenmore freezer is continuously running. It
My Kenmore freezer is continuously running. It doesn't create the vaccum when closed as of late. What should I be considering?
    Champion:
  • 363 Answers
Clean all of the door seals and all of the contact point with freezer
Posted on Jul 22, 2009
My kenmore is not pressure sealing
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
May 15, 2017 | Kenmore Elite Side By Side Refrigerator -...
Is there any way to disable the alarmon my freezer.? every time the elec blinks the alarm goes off.. so i wind up standing at the freezer thru out a storm
Lets take a look at the schematicthemobilian_55.gifFrom what I see on the schematic of this late model kenmore freezer it is possible to snip a wire and tape it off to the alarm circuit.
themobilian_2353.jpgthemobilian_2354.jpgthemobilian_2355.jpgthemobilian_2356.jpgthemobilian_2357.jpg
May 12, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
Freezer is 4 months old, when we closed the door it used make a vaccum sound like it was sealing now it no longer makes that vaccum sound.
it doesn't mean the fridge door gasket isn't sealing properly, if just means it has worked itself into a permanent seal. if you aren't having any problems with the fridge, don't worry about it.
Nov 13, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore model No. 253 11312100
Hi, No this freezer is not a self defrosting model. If it is defrosting while the compressor is running, you have a major problem.
If the compressor is not running, check the outlet for 120V and then check the thermostat to see if it is in the on position. If the control is on but the compressor os not running, check it for continuity. It must show closed while in the on position.
I hope this helps. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | Kenmore Freezers
Freezer vaccum seal not working
check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
Dec 27, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezers Logo
585 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
