Question about ASUS P5GZ-MX Motherboard
I have asus mother board P5GZ-MX and the problem is i can't turn off the vga onboard on this motherboard....Please help me with the best solution...
  • ASUS Master
  • 5,660 Answers
Did you install the graphics card first, then try to install the drivers from the graphics card's CD? This
method is doomed to fail.
Why?
Because Windows 'sees' a new hardware device, and tries to match up one of it's generic drivers. There
wasn't any drivers installed from the CD, so Windows just found the next best thing.
The drivers CD should have been installed first, then the computer turned off, unplugged from power, and
the graphics card installed.
Now the monitor is installed to the graphics card, and you're on your way.
This bypasses the default setting of using the on-board VGA.
What to do now? Delete the software you have installed in your computer, and start over. (Start>Control
Panel>Add/Remove Programs>Graphics software>Remove)
Also you may want to see if an IRQ has been set for PCI VGA. (It's Plug n' Play or otherwise known as PnP)
Go into BIOS Setup, and set an IRQ for the PCI VGA (The term you'll see is -> Allocate IRQ to PCI VGA)
How?
Don't know if you've entered your BIOS Setup before. If so, disregard Number 1 below. (I'm not trying to insult your intelligence)
1.After you press the Power On button, the computer manufacturer logo screen will come up, (or instead
of a pre-built computer manufacturer name, it will be Asus. Computer manufacturer logo? Examples: Dell, Gateway, HP, and so on) Watch your monitor screen closely. As SOON as you see the logo splash screen,
start tapping the Delete key. Tap in 2 second intervals. You will now be in the BIOS Setup utility.
2.You're in the Main Menu. Look across at the headings. Second one over -> Advanced.
Press the Right Arrow key on your keyboard. Advanced will now be highlighted. Press the Enter key.
Now you're in the Advanced sub-menu.
3.See the ->Onboard Devices Configuration heading? 6th heading down. Use the Down Arrow key, and
highlight ->Onboard Devices Configuration Now press the Enter key.
4.See the ->Advanced PCI PnP Settings heading? Use the Down Arrow key to highlight it. Press the Enter
key. Now use the Down Arrow key and highlight -> Allocate IRQ to PCI VGA. Use the Right Arrow key to
highlight Yes, or No. Either Yes, or No, will be to the right. You want it to state Yes. Use the Minus key,
( - ), and Change Value. Change it to -> Yes
Now press the Enter key. Then press F10, and the y key. (It will look like a capital Y for clarity. You'll
be tempted to hold the shift key down, and press the y key. This = NO. Just press the y key. The y key is
for Yes. ->Yes you want to save changes)
Your computer will restart.
Posted on Jul 17, 2009
  • joecoolvette
    joecoolvette Jul 17, 2009
    I forgot to ask if you have the Motherboard Manual. I see eng omran 77
    gave a direct link. Good man! In case the direct link doesn't work for
    you, here is the download page from Asus.com/Support,
    http://support.asus.com/download/downloa...
    Go down the list until you see the heading -> Version E2954
    (P5GZ-MX User Manual 2nd Edition for English Edition (E2954)
    To the right of -> Download from, click on China
    (It's a better link than Global)
    Give it at least 30 seconds to download. Let it download all the way before looking through it.
  • 2,567 Answers
1. Enter BIOS Setup by pressing <Del> key during the Power-On Self Test.
2. Select the "Advanced" menu.
3. Go to the "Chipset" sub-menu.
4. Change the "Boot Graphic Adapter Priority" option from "Internal VGA" to "PCI/Int-VGA".
5. Save the settings, & exit BIOS Setup.
Here's a link to the motherboard's user manual in case you need any further details:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5GZ-MX/e2954_p5gz-mx.pdf
I have an Asus P5GZ-MX mother board and all i get on screen is a message that says No Signal help Me
Your problem is with getting video from your graphics card. I would suggest you check your cables from your monitor side and then the cable that attaches to your video card one side or the other may not be connected tightly. Unplug them and replug them in make sure on both ends they are on tight and screwed down tightly. If they are both tight on both ends then the problem is with your video card. If its been working ok all along then it possibly may have failed and you may need to replace it.
I hope this helps you out and if it does please leave a Yes on the response that I have given you. Thank you.
Apr 08, 2011 | ASUS P5GZ-MX Motherboard
I don't have graphic driver for motherboard P5GZ-MX
Hello ccccc0000nnn!
Asus has the graphic driver for your P5GZ-MX motherboard available for download on their website. The link for your motherboard is P5GZ-MX
Just pick your operating system from the pull down menu and then scroll down to VGA and click the "+" sign.
Nov 22, 2010 | ASUS P5GZ-MX Motherboard
P5gz-mx VGA driver
Access the manufacturer's web-site:
http://usa.asus.com/Search.aspx?SearchKey=P5GZ-MX
and then click "download".
Oct 15, 2010 | ASUS P5GZ-MX Motherboard
Which Graphics Card is suitable and best for my mother board ASUS P5GZ-MX plz suggest me as early as possible
gaming card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6705531&CatId=1558
usual use card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4035118&CatId=1558
Oct 08, 2010 | ASUS P5GZ-MX Motherboard
Pci express will not work
Your N9600GT provides two HDMI out puts for dual display.
Even though you are currently only using one HDMI. Switch your monitor cable to the other HDMI out put. See if you now have display.
Also while in the bios allow, Page 2-27 in manual, Allocate IRQ to PCI set to [Yes]. Page 2-24, Internal Graphics Mode Select, [Disable]
Luck!
Mike
Oct 07, 2009 | ASUS P5GZ-MX Motherboard
My computer won't detect ATI RADEON SAPPHIRE X1550 256MB
go to bios and enable it to detect graphics cards most bios have an option for onboard only or onboard and external graphics adapters
May 04, 2009 | Sapphire ATI RADEON X1600Pro 512MB...
ASUS P5GZ-MX Motherboard Logo
912 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
