Here is a link to the manual that you might want to check out before getting a service. It has a procedure for resetting to factory default for example - http://pdfstream.manualsonline.com/8/8cec3a30-3b02-49ab-8663-ad465519e5ce.pdf
SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
SOURCE: Wavy picture
This EXACT thing just started happening with my WS-48513. Anyone have any ideas?
SOURCE: Mitsubishi 55" Projection TV / Horizontal Wavy Lines at Start Up
this is very common with these sets. the fix is to replace 11 very very smal capacitor on what is known as the hypermodule. The ideal sitation is to replace the hypermodule. if you can find it. I can do this repair. I have done about 10 at the shop. if you need to i would suggest finding someone who is very experence in surface mounted repair
SOURCE: mitsubishi diamond WS-65909 WILL NOT TURN ON
Are you getting the 2,2 blink code?
If you are I am the one you want to talk to.
I have repaired hundreds of these sets and know them very well.
Let me know and I will assist you.
If this has helped you rate this solution as I do this here for free.
SD TECH
Testimonial: "THANK YOU WILL TRY TO LOCATE FUSE"
SOURCE: i need to find to
I set up this link below which will take you directly to the site where you can get one.http://www.ebay.com/itm/Mitsubishi-WS-65313-screen-frame-nice-condition-/150557898687?pt=LH_DefaultDomain_0&hash=item230df337bf
