I want to use the projector on a desk , the projector is normally on the ceiling
  • vk2zzs Jul 17, 2009
    hello its a Sony VPL-PX30 , i want to know how to invert the image 180 degrees, thanks for your help
  • 3,741 Answers
Invert image flips the image from top to bottom, to compensate for ceiling mounting a projector upside down. Projectors typically ceiling-mount upside down, because most have a built-in offset that allows you to mount the screen at a comfortable height, yet still project an image without tilting the projector and causing keystone distortion.
To switch on the Desk Control Panel:Activate the Desk Control Panel by pressing anywhere on the touch screen. thanks.keep updated.
Posted on Jul 17, 2009
  • 453 Answers
You can use the projector on the desk but more of the functional keys are located in the bottom and the sensors are avaialble there for the remote because of which it can become difficult to operate.
But if you are not worried about the above then the projector must be arranged in such a way that the image fits in the screen perfectly.
The height of the projector from the ground, distance from the screen and wiring have to be taken in to consideration.
If I can know the exact model of the projector you are using then it would be great for furher suggestions.
Kindly comment.
Image upside down epson projector
Be sure the setup matches whether the projector is on the desk top or ceiling mounted.
Dec 16, 2013 | Office Equipment & Supplies
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
Our picture is upsideddown how do you rotate the picture???
Go to the Option menu and select Installation then if your projector is sitting on a table or shelf, select "front/desk". If your projector is installed on the ceiling, select "front/ceiling".
That should solve the problem.
Aug 22, 2011 | Panasonic PT-AX200U Projector
My project image is flipped horizontally on the screen, but displays normally on my laptop. How do I fix my projector image?
The projector may have a menu function for flipping the image dependent on whether it is merely set on a desk, or mounted upside down on the ceiling. See the manual, printed or online.
Feb 02, 2011 | ViewSonic PJD6211 Projector
Image is upside down. how to fix?
Projectors have the ability to flip the image for when they are ceiling mounted, or laying on a desk. You have to go into menu and change the option based on where you have the projector located. You can find the option in the Menu, under Setup and Basic under the Projection sub-menu. Will be either Front Table, Front Ceiling, Rear Table or Rear Ceiling.
Jan 27, 2011 | Vivitek D940VX Projector
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
Computers & Internet Logo
David Payne
David Payne
