What year and vehicle are we dealing with? On GM vehicles the chime goes through the driver door speaker and when they go bad you loose sound and or it's very very quiet..
Disabling the door and seatbelt chime in a 2008 Saab 9-7X typically requires accessing the vehicle's computer system to adjust the settings. However, it's important to note that tampering with safety features like seatbelt reminders may not be legal in some jurisdictions, and it can also pose a safety risk.
If you're still determined to disable the chime, here are some general steps you might follow:
Consult the Owner's Manual: The owner's manual may contain information on how to adjust the chime volume or disable it. It's always a good idea to start here to see if there are any manufacturer-approved methods.
Check for Dedicated Fuses or Relays: Some vehicles have dedicated fuses or relays for the chime system. You could potentially remove or disable these components to silence the chime. However, be aware that this may also affect other systems in the vehicle.
Use a Diagnostic Tool: Modern vehicles often have customizable settings accessible through the onboard diagnostic (OBD) port. A diagnostic tool compatible with your vehicle might allow you to access these settings and disable the chime. However, this may require specialized knowledge and equipment.
Visit a Dealership or Automotive Technician: If you cannot disable the chime on your own or are concerned about potentially causing damage to the vehicle, consider visiting a dealership or automotive technician. They may be able to adjust the settings for you or offer alternative solutions.
Consider Aftermarket Solutions: There are aftermarket devices available that claim to disable seatbelts and door chimes. However, their effectiveness and legality may vary, so proceed with caution if you choose this route.
Before proceeding with any method to disable the chime, carefully consider the potential consequences and whether it's worth the risk. It's also important to remember that seatbelt reminders are a safety feature designed to encourage proper seatbelt usage, which can save lives in the event of an accident.
your best bet , take it to a qualified repair shop. Have it checked for DTC'S - diagnostic trouble code's
Audible Warnings Description and Operation
The audible warnings alert the driver of a system concern or a critical vehicle condition. The instrument panel cluster (IPC) generates audible warnings through an internal acoustic speaker. The IPC receives audible warning requests via the serial data circuit. If the IPC receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
Door Ajar Warning
The IPC activates the door ajar audible warning as requested by the body control module (BCM). The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The door ajar warning sounds and the appropriate DOOR AJAR indicator illuminates in the driver information center (DIC) when the following occurs:
• The body control module (BCM) determines that a door, driver door, passenger door. The IPC receives a serial data message from the BCM indicating the door ajar status.
• The vehicle is not in park. The IPC receives a serial data message from the BCM indicating the gear position.
• The vehicle speed is greater than 8.05 km/h (5 MPH). The IPC uses the vehicle speed information from the ECM to calculate the vehicle speed.
Fasten Safety Belt Warning
The IPC activates the fasten safety belt audible warning as requested by the BCM. The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled. The IPC receives a serial data message from the SDM indicating the drivers seat belt status.
If the seat belt is buckled when the ignition is turned ON, the chime will not sound. If the seat belt is buckled while the chime is sounding, the chime will stop. If the seat belt is unbuckled after the initial transition to ON, the chime will not sound.
Key-In-Ignition Warning
The IPC activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open. The IPC receives a serial data message from the BCM indicating the door ajar status.
• The BCM determines that the key-in-ignition switch is closed and the signal circuit is low. The IPC receives a serial data message from the BCM indicating the key-in-ignition status.
Lights On Warning
The IPC activates the lights on warning as requested by the body control module (BCM). The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The lights on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the drivers door is open and the signal circuit is low.
• The BCM determines that the headlamp switch is in the park or head position.
Park Brake Warning
The IPC activates the park brake audible warning as requested by the BCM. The BCM sends a serial data message to the IPC indicating the chime frequency and duration.
• The body control module (BCM) determines that the park brake is applied.
• The vehicle is not in park. The IPC receives a serial data message from the engine control module (ECM) indicating the gear position.
• The vehicle speed is greater than 8.05 km/h (5 mph). The IPC uses the vehicle speed signal information from the engine control module (ECM) in order to calculate the vehicle speed.
Additional Warnings
The following warnings have an associated instrument panel cluster (IPC) indicator or driver information center (DIC) message:
• Check Oil Level
The IPC activates the audible warning as requested by the BCM. The BCM sends a serial data message to the chime producer indicating the chime frequency and duration.
• Low Fuel
• Oil Pressure Low Stop Engine
• Reduced Engine Power
• Trans Hot Idle Engine
• Turn Signal On
chime module built into instrument cluster -module circuity
chime cant be disabled or removed without electronic mayhem
chime does many functions and alerts on all cars
There isn't a chime module , built into instrument cluster ! Door Ajar Chime
The door ajar chime feature is controlled by the smart junction box (SJB). The driver and passenger door ajar switches, and the lift gate are hardwired to the SJB. If any door or lift gate is sensed as being open, and the ignition switch is in RUN/START position, the SJB will process the input and sends a chime request to the instrument cluster over the controller area network (CAN). Safety Belt Warning Chime
The safety belt chime feature is controlled by the restraints control module (RCM). The driver safety belt switch is hardwired to the RCM. The RCM communicates with the instrument cluster over a hardwire connection. If at any time during the first 6 seconds after the ignition switch is placed in RUN the driver safety belt is sensed as being unfastened, the RCM will process the input, and in turn, sends a chime request to the instrument cluster.
Do you know what C.A.N controller area network is ? Serial data communication bus.
Do How to Diagnose Controller Area Network CAN
If the chime includes the cab light staying on as well: There is a door switch in both the driver and passenger side doors that needs attention. I too had this problem. Solution: squirt wd40 onto the switch located near the door latch on both driver and passenger side.
There is a BLACK/PINK thin wire going up into steering column. Cut that to silence the chime when your key is in the ignition. Or before doing that locate the chime module under your dash (just follow the sound) and unplug the module from the connector and that will do it.
Key in ignition chime ?
Saturn L-Series ?????? L what ? L100 ,L200 , L300
Audible Warnings
The body control module (BCM) will provide an audible warning for various events relating to the vehicle. The functions that provide an audible warning are the key in ignition, the lights on, the occupant restraint (seat belt) and the park brake.
Key in the Ignition Audible Chime
The BCM will provide an audible chime if the key is left in the ignition in either OFF or the accessory position with the driver's door open. The chime rate for this is 150 chimes per minute. The key in the ignition chime has a higher priority than the lights on chime.
Lights on Audible Chime
The BCM will provide an audible chime if the park lights are on and the driver's door is open. In addition, 1 or 2 other conditions exist. The key is out of the ignition, or the key is in the ignition in the OFF position, and has not been turned. The BCM will chime at a rate of 200 chimes per minute until the conditions are removed.
Occupant Restraint Audible Chime
The BCM will provide an audible chime based on the class II message received from the SDM if the driver's seat belt is not buckled when the ignition is turned to run or crank. The chime rate for this feature is 50 chimes per minute.
Park Brake Audible Chime
The BCM will provide an audible chime for park brake when the park brake is applied and the vehicle speed is higher that 3 mph. The chime rate for this feature is 200 chimes per minute.
You can't disconnect anything . The problem has to be fixed .
Audible Warnings (Chime)
Chime Rate Per Minute
150
200
Occupant (Seat Belt) Restraint Audible Chime
50
200
Content Theft Pre-Alarm Audible Chime
200
Telltale Chimes
The body control module (BCM) will provide 4 chimes for each telltale activation per ignition cycle, at a rate of 150 or 200 chimes per minute. The chimes are limited to 1 chime event per telltale for each ignition cycle. The power up telltale function will not activate the telltale chime function. If the telltale becomes active during a cycle then the chime will sound.
The following telltales will activate the chime function:
• Low Washer Fluid
• Change Oil Soon Indicator
• Brake Fluid Low
• Oil Pressure Low
• Coolant Temperature Hot
• Low Coolant Level
• Low Fuel Level
• Antilock Brake System
• Volts Light (Generator)
• Supplemental Inflatable Restraint System (Air Bag)
• Trunk or Hatch Ajar
Having the vehicle checked for DTC'S - diagnostic trouble code's in the BCM would be the first step in the diagnostic procedure .
DTC B2965
When the ignition key is seated in the ignition switch, the key-in-ignition switch contacts the close, grounding circuit 80. The body control module (BCM) monitors the state of the key-in-ignition switch, the state of the ignition switch (OFF, ACC, or RUN) and the driver's door to control the key-in-ignition chime.
Hello! If I understand you correctly; Loss of low speed windshield wiper, loss of rear window defogger...And Chime...All are common to the Integrated Control Module (ICM)...However, based upon minimal information I do not just change parts...If you were to expand on the problem we'll see if we can pin it down via troubleshooting and save you money...I'll investigate it further, but first you need to respond with a clearer explanation...Awaiting your reply...Guru...Saailer
Good news - they're adjustable. The radio is used to adjust the vehicle's chime level. To change the volume level of the chime, press and hold push-button 6 with the ignition on and the radio power off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold push-button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display.
Note: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected.
I have a 2006 SV6 with the power sliding doors. The problem that I found was with the contacts on the door
( They are called plungers) the movable pins were losing connection
with the fixed part The plunger is very easy to replace if you can find
one. The plungers are covered with a rubber cover and is held in place
with 2 plastic pins. My Pontiac dealer could not even find one in his
books or even a picture of one, and claimed that he had never had anyone
come with a door
problem. My Chevy dealer said that it came with a wiring
harness that is not needed for $154. The cure that I came up with was to
take the plunger block apart (it snaps together)and replace the rusted
out springs then solder 3" wires to the end of the plunger pins (they
solder easy) to the tabs that go to the plug(pop out the tabs or you will melt the plastic. It took about 45 min. now
the doors work like new and will never loose contact again
