Question about Troy-Bilt Garden
Can i see the models from 1983 to 1985,i need a belt so i can use reverse again but i dont now my model or size. my husband died 3 years ago. if i could see some pictures from the 1980's mine has a potatoe fork you can hook on.
I need a manel for older troybilt horse tiller. you have to hold it in gear for it to till foward. I would greatly appricate on how to optaine a useres manel. Im despert.
pricenina97@yahoo.com
Posted on May 29, 2010
  • 22 Answers
Your question doesn't give enough detail to properly answer. Do you know if the tiller is a Horse model or a Pony model? Troy Bilt made both models back in the timeframe you noted. The Horse model had tires that required air to inflate. The Pony model likely had hard rubber tires in that era. The Horse models had a reverse disc, no belt. The Pony had a belt.
Once you know which model you have - look for your closest Troy Bilt dealer and see if they can track down the part for you. They might appreciate it if you could provide the serial number - which is located on the pipe connecting the tiller transmission front half to the back half, where the tines are located. It's stamped right into the metal tube on both models.
Posted on Oct 10, 2009
Why does the belt keep breaking on my dryer model dvlr223ee2ww?
perhaps bad bearings either in the drum supports or the tensioner pulley .
Aug 30, 2015 | Dryers
I need to no the belt size for the v belt on a scott rearline tiiler the model number is 6070s
This is what I found
Forward belt is a 1/2 by 27 (L4270 or 4L270, Oregon 75-427 )
Reverse belt is a 3/8 by 30 (L3300 or Gates FHP 3300)
May 30, 2014 | Ardisam 5.5 Hp Rear Tine Rototiller
Code 15 when checking appears, experiencing bad idling and speedo not working. when i throuw water all over the enjin the problem is gone for about a week.
how long ago was this car a daily driver (fresh fuel)?
and how long ago did the speedo die... my guess is unrelated to all else but the speedo must work for the EFI to work driving fast, but not
so idling, and not moving.
no year , no model, a 1973 civic? I have no idea.
no engine stated, I4, 6? size?
I love the water, trick but is the top method from finding
bad HV ignition wires, fast. yours does opposite. that.
if car is in USA< no clues there, it's older than 1996.
code 15 is http://www.troublecodes.net/honda/
IGNITION output.
depends on year and engine, type.
on old cars this signal means the ignitor and coil signals are bad
on newer cars, it can be the ECU spark signal bad.
there are 3 ECU designs, in all the years,
OBD1 comes in these flavors
{1}PGM-CARB.
{2}PGM-FI four cylinder engines.
{3}D5Z1 engine except California.
yea?
model and sub model?
engine type.?
and country if possible.... always helps, ?
Jan 15, 2014 | Honda Cars & Trucks
I was driving on highway when drive belt came loose and I lost power to the vehicle. I was able to come to a safe spot but the battery died there. Belt is NOT broken but lose. My belt was bought at...
You need to inspect all of your pullies and make sure that all of them spin freely and have no side-to- side wobble. Also inspect your belt tensioner to make sure it is not broken. some cars have problems with the belts coming off if snow or water gets into them. There are technical service bulletins that address this problem on a couple of vehicles. I don't know if they apply to yours because the problem as I am reading it, does not have Year, Make, Model, or Engine size in the description. If the belt seems like it is way too long by several inches, you may have either a pully that is completely missing or the belt is not routed correctly.
Jan 19, 2011 | Nissan Quest Cars & Trucks
I have an old White, model STD270 with a disintegrated belt
A belt replacement should be easy, first you need to measure how long a belt is needed by taking a piece of twine and placing it where the belt will go and using it to measure how long the belt need to be. Belts come in different sizes such as 14 1/2, 13 3/8 etc.
May 22, 2010 | Sewing Machines
Need a manual for a Craftsman belt & circular sander
I found a PDF file on Sears.com website for the original manual for my belt / circular sander.
Oct 21, 2009 | Tools & Hardware - Others
My 1993 mtd lawn mower will not get out of reverse
the belts are the wrong size,you may need to get the next size up.go to partstree.com put in your model #.it should be able to tell you what size you need.hope this helps
Jun 12, 2009 | Mtd Garden
Both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
mortimer5918@bellsouth.net
Mar 24, 2009 | Garden
Our refridgerator fan motor(samsung side by side)
wake make is this and can u use the fan of the old motor?
Sep 03, 2007 | Refrigerators
Garden Logo
329 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
