Televison & Video Logo
Paula Hyche Posted on May 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a vizio E471VLE. It is making high pitched noise after about a minute of being turned on. Then horizontal lines replace picture, then goes black. Any ideas
Marvin
Level 3:
Top Expert:
  • Vizio Master 85,242 Answers
  • Posted on May 02, 2016
Marvin
Vizio Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29037596
Points
266281
You have a failing main circuit board, it will be cheaper to replace the TV than try and repair it.
Vizio tv repair?
Sounds like power supply board is bad
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Vizio 32 Inch, turn on completely fine for about 20-30 minutes. Then sound goes out accompanied by high pitch noise and picture has varying lines or colors through it. Won't power off, have to un
Are you a decent do it yourselfer? It sounds like it is the capacitors. What happens is they get hot and expand (the top of the Capacitor). The top will be dome shaped and it will look like the top is splitting open. You can buy (about $1.50 ea.) the capacitors at your local electronics store (not Radio Shack they usually don't have a high enough amp).
You will need to take the back off and look at all of the capacitors to see which ones are bad. Usually it will be 2 or 3 of the larger ones but there could be more. Next you will need a soldering iron with a fine tip and some wicking material. How could are you at soldering and de-soldering? before I go on.
If you let me know the model # of your set I can be a little more detailed also.
My 32 inch Vizio TV will turn on but within about 5 - 10 minutes, the screen goes to nothign but vertical lines. The T V makes a very high pithced noise and ten turns it self off.
The high pitch sound may be coming from the power supply module or from the backlight inverter boards.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
2answers
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
High Pitched Ticking Noise
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
