Question about Fenton Technologies Computers & Internet
What problems do these technologies solve in UPS?
  • 2,567 Answers
1. Provide conditioned clean AC power to computers & other peripherals (except laser printers, which should not be powered by UPS).
2. Protect equipment from the harmful effects of brownouts & sags.
3. Supply power to equipment during a power outage for a specific time, either to allow for the graceful shut down of systems, or to keep the systems working during the power outage (depending on the battery capacity).
Posted on Jul 17, 2009
Apc smart ups 1000va when we insert the batteries the n-channel mosfet transistors was burn. what the causes and how to solve this problem.
a relay is jammed?? fused shut or bad switching silicon
replace the controller board
instead get a new one too many things to resolve
if your batteries burn out the inverter then its some timing issue
not worth it to repair the board
replace the whole control or new one!!! and reuse the cells {ebay}
Dec 11, 2014 | APC Smart-UPS 1000VA UPS System
Replaced battery but system is still chirping. replace unit?
i suspect the inverter circuit of your UPS is already faulty... btw can you give us more detail on this problem?
Mar 22, 2012 | TriPro Power Tripro Maruson Technology UPS...
Slow connection
Your router has small NAT table and this slow down your Internet connection. You can solve router slowness with Router Commander software. This software accelerate your router using dynamic NAT feature and other technologies that speed ups router. You can get it from www.routercommander.com . Good Luck.
Nov 03, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Hi i m using powercom ups but whenever i make the connections my computer restarts againand again i dont know why???
Friend have you plug and switch the ups properly, If so then check that you have also plug your computer pin properly into a ups. If this is also right then there might been problem in a UPS charging or in ups. It might also be a system fault. Just check out the system fault by applying the direct connection to the socket. If this solve your problem then check out all the procedure of ups to work and if this does not solve problem repair ups or charge it properly. If the ups is also not charged then it also make a problem to start for sometime.
May 13, 2010 | Computers & Internet
Ups not working on generator power
you will try to change the fuse in ups
Aug 24, 2009 | APC Back-UPS CS 500VA UPS System
Batery faillure
Advanced Battery Management Technology Prevents Premature Failure and Significantly Extends Battery Service Life
Batteries are the most critical component in the reliability of any UPS, but they face three fundamental challenges: All Batteries Need Charging
But extended charging significantly shortens battery life. Most batteries are charged with a trickle-charging process (a constant voltage feeding a low current to the battery). This method dries the electrolyte and corrodes the plates, reducing potential life by up to 50%.
Batteries Take Time To Recharge
Users can’t wait. During prolonged power outages, the UPS batteries will discharge and not recharge until the power returns. When there is a subsequent power failure before the batteries recharge, the computer will not have full backup time. Overly rapid charging can cause premature battery failure, so the trick is to charge at the fastest rate that is safe for the battery.
All Batteries Will Eventually Fail
The question isn’t “Will it happen?” but “When will it happen?” Because UPS batteries are valve-regulated, sealed lead acid, there has previously been no practical way to provide the user with any meaningful advance notice that batteries need to be replaced. In the past, the only way to know when the batteries were dead was when the power failed and took your computer down with it. Until now, typical UPS batteries have required replacement every two to three years.
Our exclusive ABM technology solves these UPS battery problems. It significantly increases the life of UPS batteries (see Figure 1), provides the fastest safe recharge time, and provides reliable advanced notice when the batteries need replacement. By extending battery life and virtually eliminating this major cause of surprise load crashes, we are able to offer the industry’s longest and most inclusive warranties on all products that incorporate ABM. No other manufacturer can make this statement.
ABM technology is available on Powerware 5115, 5125, 9120, 9125, 9140, 9155, 9170+, 9355, and BladeUPS UPSs.
Jul 02, 2009 | Powerware 9120 UPS System
Power failure
the smart up 2200I, can not on again, each time I try to on it, it use to show a prompt light as if is about to on, how can I solve the problem?
Dec 17, 2008 | IBM APC Smart UPS 2200I UPS System
Electrical noise
You have a loose ground on the outlet. check it out................
One other thing, you have bought the worst, cheapest design and the least protective product in the world without AVR technology.
I am a power quality engineer and I loath APC quality.
www.storminproteciton.com
check out some real UPS that might do better.
Dec 08, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
The AC output power id to low, like 96VAC ; its bad shoul be 115 VAC
Very bad!. Trash this and get a UPS with AVR technology and line interactive. 96V will burn up your power supply and this junk has no AVR technology that will help step it up. Also your load may cause a serious voltage drop, that means your UPS is way too small as it is. I suggest you think about going to a 1000VA or higher.
www.storminprotection.com. look on my web site, and check out the UPS's and I would be happy to sell it to you at my dealer cost to solve your problem.
May 22, 2008 | Belkin (f6h375-usb) UPS System
Computers & Internet Logo
163 people viewed this question
Top Fenton Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Fenton Technologies Computer and Internet Expert? Answer questions, earn points and help others
