This may be a multi issue problem. Start with changing the wii position. If ur trying to run a disk horizontal, then chamge unit position to try it verticle. If that doesnt work u may have to do some machine surgery.
I started getting the same problen on my Samsung since I think it started when I moved to the US but can't be sure. Uninstalled, reinstalled, chamged setting, nothing works to to allow streaming
Mechanism is the same for all cartridges. Some printers like HP have an index finger space on it that you press down to release. See if your cartridge has similar groove.
If you look along the side of the machine you will see 2 lips on both sides,pull it open en you will see the toner cartridge,pull out the cartridge and push the new one in.
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine 2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds 4. Plug it back it and wait for the insert cartridges message 5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Lexmark X6170 uses these two ink cartridges: - Black Print Cartridge (18L0032E) Colour Print Cartridge (18LX042E) It is highly recommended that you use the original cartridges as the cartridges and ink vary from printer to printer. However, if you are unable to find the cartridges, you may look for refilling option.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
i cant help you with your problem completely but every time i change the ink the printer states to install the correct cartridges and or that my ink level is low and will not print
all previous occasions with the cannon mp150/160 if there's such a word as stubborn can apply to computer printers i have had to keep rebooting the programming that is switching off and on at length the power supply until the printer finally works or offers the alternative message to press the start button
i have 2 cannon printers mp150 and mp160 because it is just about the same price to buy a new printer than 2 new cartridges
