Question about Sony VPL CS5 Multimedia Projector
How to change fuse sony vpl-ds100 - Sony VPL CS5 Multimedia Projector
4 Suggested Answers
maklean
  • 1665 Answers
SOURCE: Blue dots
http://www.nodevice.com/user_manual/sony/projectors1/vpl-ds100.html
Use this link to download your manual troubleshoting tips, to see if problem referred on.
Posted on Aug 09, 2008
SOURCE: Sony VPL-DS100 will not turn on
I had same problem. The cause was a blown fuse (T5.0 Amp 250V). You have to open the case and then get below the print that is under the alloy cover. it is quite simple to fix. A fuse costs 60 cents.
Posted on Jun 15, 2009
SOURCE: How do I reset the lamp timer on the Sony VPL-DS100?
The answer above is incorrect. You do not hit all four button simultaneously, The "trick" is that you need to press each button (in order) but quickly. The Sony manual wrongly lead you to believe that the bottons are to be pushed "for less than five seconds each" when it means to say that you need to press all 4 buttons as fast as possible (i.e. 2 or 3 seconds for all 4 buttons).
Posted on Jul 14, 2010
Blue dots
Aug 09, 2008 | Sony VPL-DS100 Multimedia Projector
There is gold holes they have to be removed
Those are the mounting bracket threads. They don't come out. Take out the 5 long brass screws and the one short silver screw. Flip the whole thing over and take off the top.
Jul 30, 2010 | Sony VPL-DS100 Multimedia Projector
Yes, press RESET, <, >, ENTER keys on remote simultaneously to reset lamp timer. Display of lamp will also change to zero.
Make sure projector is just plugged in and should not power On (in standby mode) to reset lamp timer.
Jun 03, 2010 | Sony VPL-DS100 Multimedia Projector
Where exactly is the fuse located for Sony VPL DS 100?
Take out the screws on the bottom. Flip it over and take off the top plate. Pull (from the connectors) the wires going over what looks like a steel plate with several small holes. Take out the screws (6 total) holding that plate and the circuit board on. Pull off the steel plate and the plastic under it. Lift up on the circuit board under that: there are to connectors on the underside that have to be removed. Once you get it out, the fuse is near the end, about 3/4" long and ceramic white.
Feb 07, 2010 | Sony VPL-DS100 Multimedia Projector
Apr 18, 2009 | Sony VPL-DS100 Multimedia Projector
Sony VPL-DS100
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
Jul 06, 2008 | Sony VPL-DS100 Multimedia Projector
Sony VPL-DS100
Hi DianeMcF
There is only two things that could cause a pink colour to appear on your screen.
Try using a different cable - which I'm sorry to say - I doubt will fix the problem.
This is most probably a LCD that will have to be replaced , and do take my word for it that this is not something you would want to replace yourself as it is extrememly difficult and a very delicate process not to harm the other LCD's.
May 23, 2008 | Sony VPL-DS100 Multimedia Projector
Sony VPL CS5 Multimedia Projector Logo
133 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
