Question about Sony KP-46WT510 46" Rear Projection HDTV
Kp-46w510 Convergence. The red is out of line and will not move trying to do it manually or autoamtically
  • 346 Answers
Replace the stk ics
Posted on Nov 24, 2007
I have a sony projection tv kp-43ht20 and the picture has gone pink. Can you give me an idea what has happened? Is this a fixable problem? I can't afford a brand new tv at this time. Thank you for your...
Sounds like the convergence is out of adjustment....moving the set can cause this as well as components chaging value with age....The kp43ht20 is an older set and may not have the alignment setup in the menu as with the newer sets...but you can go thru the menu to find out...if there is one, then you can try to align the convergence...usually there will be a crosshatch on the tv...when aligning convergence there will be a blue setting and a red want to select red first and try to get the lines lined up as close together as possible on the red adjustment..then you go to the blue adjustment and do the same...the outcome should be as close as possible to white when everything is lined up properly
Dec 30, 2010 | Sony KP-43HT20 43" Rear Projection...
Flash Focus does not correct convergence problem and i cannot manually adjust the red convergence to proper alignment. Red does not move laterally only vertically. Picture is offset to the right with red...
No,any colors lines mis alignments.The tv convergence board parts are dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be replace on the tv convergence board.To solveved convergence problems.The shop,will cost u $300-350 for parts and labors.
Aug 10, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony kp-53xbr45 please let me know step by step how to enter convergence service thank you
To enter into the convergence service of your sony, follow the steps below;
  1. Press "Menu" on the remote control. Use the up- or down-arrow button to move the cursor to "Setup" and then press "Return."
  2. Use the up or down arrow to move the cursor to "Convergence" and press "Return." This will bring up the convergence-adjustment screen.
  3. Press the up or down arrow to move the cursor to the line you want to adjust (either vertical or horizontal for red and blue) and press "Return."
  4. Press the up or down arrow again to move that line until it converges with the center green line and press "Return."
  5. Repeat to adjust the other lines until all three lines converge and are seen as a white cross.
  6. Press "Menu" to exit the convergence menu and return to the original screen.
You can as well follow these steps;
  1. Press the "Power" button to turn your TV on.
  2. Wait at least 30 minutes before you adjust the convergence in your television. This allows your TV ample time to warm up before you make the adjustment.
  3. Turn your TV to a cable channel or to an antenna channel with a picture that you can see. A music channel with a static shot of music notes isn't the kind of picture you need. Instead, look for a picture like what you would see on a movie, sitcom or drama.
  4. Press the "Flash Focus" button located in the front panel on your TV. You may need to open a hidden compartment on the front of your TV to access this button. The convergence will repair itself automatically after you hit this button. It may take several minutes.
Any of the two processes are detailed steps on how to enter your convergence service.
Take care
Jul 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
I can not get convergence to work.
you will need to install a convergence repair kit. The Sony type 1 convergence kit from is the correct one for your model, the kit contains the CD with instructions plus the replacement parts.
May 05, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a sony 50in rear projaction model kp-48v90 and when its on the right and left sides have a slight red streak on the sides but not in the center what can i do to fix this problem at home
U can tries go in ur convergence menu.Tries auto or manual lines up the +'s together.Not able to,ur convergence are dead.The shop will cost u $300-350 to fix convergence problems for parts and labors.
Apr 02, 2010 | Sony KP-53V90 53" Rear Projection...
Need a manual for a model kp-46wt510 tv sony
Click Sony Support to download User Manualof KP-46W510
Click Manual Zone to buy service Manual of same model.
Feb 22, 2009 | Sony Televison & Video
You need a remote that can produce the "DISPLAY" button on the Sony remote in order to get in service mode....(you could also carefully move the centering rings on the red CRT to line it up with the green CRT)
Jul 17, 2008 | Televison & Video
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Convergence problem
Sounds like bad solder connections on the convergence circuit board. Better get it looked at before the damage becomes permanent.
Jan 28, 2007 | Sony KP-EF41 41" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
357 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
