Vert lines about 1/2 in apart kind sparkling - Televison & Video
  • 215 Answers
Hi, Welcome to FixYa
It seems to be a problem with the circuit or It may be the automatic format switcher is not working properly.
Try to reset your TV for a couple of times and see if that helps. If not, you will need an expert tech to look at it.
Reset is done by disconnecting the power cord from the wall outlet for 4 hours, then power up. Do it twice. If this doesn't work then you may have to change the electrolytic capacitor of the vertical section. So better take to a technician.
It is not an adjustment; it is a malfunction of either the vertical deflection system or the auto format switching circuits.
Thanks
If you are satisfied with the reply please accept
Posted on Jul 17, 2009
Wheel is missing letters, broke off I guess. Does the wheel get old and fall apart? I haven't used the type writer in a few months. Should I get another wheel or call for repair? Thanks! Karen
The wheel usually last for many years. I'm assuming you are getting 2 vert lines in place of the missing letter (hammer face). Used replacement wheels are available for 29,95.
DickyO
Cleveland Business Machines
216-241-0027
Jan 31, 2011 | IBM Wheelwriter 6 Typewriter
I have akai 2201 television set when i start the tv there comes a horizontal line on the screen with no sound & picture kindly gudie
IT IS VERTICAL OUTPUT SRAGE FAULTY. FIRST CHECK SUPPLY VOLTAGE 18VDC. THEN CHECK OUTPUT VOLEGE 15VDC.IT IS UPNORMAL FINALLY CHANGE VERTICAL OUTPUT IC.BEFORE CHANGING IC CHECK ALL THE COMPANENTS IN THE VERT.STAGE
Aug 02, 2010 | Akai Televison & Video
The TV has a thin horizontal line across the screen. Sometimes the line has color and sometimes the line is white. Everything else seems to be working (i.e. sound, channel changing, game hookups)....
you have a vertical output problem,take something insulated and prod around board and see if pix starts to flutter,then you could have a "cold-solder" joint,otherwise its more than likely a capacitor between the vert driver circuit and the vert output circuitry,
Sep 12, 2009 | Televison & Video
20in Magnavox.A 2in black bar at top and 2ins of fine lines under
yes you got vert foldover best bet buy a new tv . you can fix it but if you replace the vert anp and the assorted caps and IF you still have a problem in the power supply in a really short time (1-2 hours) you will burn out the amp again , and blow 2 caps and a zener diode all over a regulator problem that showes it self when ever it wants too .... out 35.00 in parts and 2.5 hours labor right back where i started ....trust me you dont want to open this can of worms . if you have it done except to pay between 100.00 -200,00 for the repair and ask them to run the set for a day or so before you pick it up
Mar 26, 2009 | Toshiba 24AF44 24" TV
Vert deflection problem
You are correct about having a dry or leaky capacitor that is causing those lines to show on the top of the screen.
Check the caps with low capacitance like 1uf, 10uf, 47uf, etc.
No quicker fix for this one until you change the capacitors.
Hope this helps.
Mar 14, 2008 | Philips 32PT6441/37 32" TV
My monitor give tow horizontal lines
There should be a dry joint at the vert IC with five pin.
Resolder it, then it wold be ok.
Mar 05, 2008 | Dell P793 17" CRT Monitor
Picture problems
you have a vert sweep colapse. Fisrt thing is to get a schematic diagram and find the vert. output Ic and the clamper diode. Measure the voltage on both sides. If its low then its apossibility that the Ic was drawing loads of current and blew out the b+ feed resistor. Look on the schematic and trace back the voltage line from the vert output ic back to the sweep power supply on the secondary of the flyback transformer. check the limiter resistor to the feed and if its open replace the cap right there the resistor as well as the vertical output Ic ALL AT ONCE!!! If you dont you will cause it to go out again in a short time. Good Luck.. If you post the vert part of the schematic I will be more then happy to assist you with this repair.
May 01, 2006 | Symphonic SC3813 13 in. TV/VCR Combo
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
