Question about Honeywell Programmable Thermostat Heater
How difficult is it to replace my old Honeywell T8001C with a newer model like the TH8320U1008?
  • 8,220 Answers
Sweet ain't it? For $335 bucks I would get a dude to hook that puppy up just to make the warranty dudes stand at attention if that baby boy takes a dump. The basic terminals are all the same as any other two stage heat pump with aux heat and many special features. Dude get a dell! Seriously if you ain't a HVAC guy I would say get somebody to back you up on this one. That is just my dumb opinion.
Posted on Jul 20, 2009
  • 308 Answers
If you are careful about marking wires, and ensuring that you put things on the correct terminal, it is not that big of a deal. If on the other hand you have any doubts about being able to complete the job, it is probably better to call you local service tech. (It really is just as easy to swap wires one by one sometimes, or write/draw a diagram....) Good Luck
How do I change the battery on Honeywell Thermostat T8001C?
According to the manual for the model series (see link), only the T8002 Model has batteries. They are accessed from the right side of the thermostat. See page 14.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1431.pdf
Jan 10, 2015 | Honeywell T8001C1019 Programmable...
My 9 year old Honeywell T8001C has no display. My FAU AC power breaker is not tripped. I tried a new Honeywell RTH2510B and a RTH7500D but the Fan does not come on with either of the new units after...
This is why battery powered tstats are misleading. The battery provides the power to the tstat but your unit is not providing low voltage in order to run. Air conditioners are controlled by relays and contactors. This means your unit constantly has high voltage going to it but each component runs through a relay in order to turn on. These relays are energized by the low voltage that runs through your tstat. Your tstat is not getting this low voltage. Either your float switch on your drain line is tripped, your blade style fuse is blown on the secondary side of the transformer or your transformer is bad.
Aug 08, 2017 | Honeywell Heating & Cooling
Have the honeywell t8001c thermostat - no batteries - it holds the programming fine but not the date/time - what to do?
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 06, 2010 | Honeywell Programmable Thermostat Heater
My Model TH8320U1008 touchscreen not working. I have replaced the batteries, still doesn't work. Is there a way to reset it?
I dont think its your thermostat. The 8000 pro series is relatively new. I think is you furnace you lost 24 Volt power. Check the furnace out first. www.fastacservice.com
Oct 18, 2009 | Honeywell Electronic Programmable...
Trying to replace honeywell T8001C thermostat with new honeywell RTH7600. The old had a brown not used & a blue. On the new unit not sure where they go. Hooked it up with red,yellow,white,green &...
Red is usually hot side of transformer,yellow is for the a/c compressor,white is for heater,green is for the blower fan,now the blue could be energize for heat or the common side for the transformer,brown can also be the common side of the transformer. It sounds like you need the blue wire connected to the common side for the thermostat....but be careful. Some units use this as a energize wire and are not a common. I would find out what furnace model you have then look online and double check what this wire is or you could damage the new thermostat and/or the 24 volt system on your fau. And also always have the power to the unit disconnected so you do not ground a circuit.
Oct 03, 2009 | Honeywell Programmable Thermostat Heater
GOODMAN CPLT36-1 WITH HONEYWELL VISION PRO STAT 8000
what is the trans former voltage needs to be 26- 28 v. and is the board fused max 3-5 amp fuse I know it is on of the two check all of your wiring. good luck Tom
Jul 11, 2009 | Heating & Cooling
Replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
230 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
