Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Machine will not **** up the milk,just steam comes out when you try to make coffee
Remove and clean the O Rings.
I had the same problem, removed the o rings where the milk frother connects to, there is a green, red and black rubber O ring. Remove them and get a toothpick and clean around where they sit. You will notice a hard milk build up like when you get on your teeth. This is what is causing your problem.
........ o rings.........its as if were working on the space shuttle!!
Posted on Aug 04, 2009
mirran
  • 515 Answers
SOURCE: Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Posted on Jul 11, 2008
SOURCE: steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Posted on Jul 05, 2008
SOURCE: Flashing red light. Nespresso Citiz & milk coffee machine.
I had the same problem today. "http://www.singleservecoffee.com/archives/007209.php" talks about filling the frother above the max line, so that the whisk does not suck in air and does not pop off. I tried it and works. Make sure you close the lid properly to avoid spillage.
Posted on Feb 05, 2010
SOURCE: There is no milk coming out of the frothing part
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
Posted on Jun 21, 2010
  • 906 Answers
SOURCE: kitchenaid artisan coffee machine - steam wand
good day,
hope this link below will solve your problem..
kitchen
Posted on Aug 04, 2010
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
THE FORTHED MILK NOT HOT
Try steaming less actual milk and allowing the froth and expansion to make up the volume you need for the size of the cup. This allows you to steam the milk longer achieving a hotter froth.
Dec 20, 2014 | DeLonghi Magnifica Coffee Makers &...
Steam comes out from the tray grill
Sound's like you have a crack somewhere in the tray,
You could try locating it and sealing it.
Jan 15, 2014 | Jura Capresso Impressa F7 Espresso Machine
It shoots too much water coffee come out watery
try adding more coffee to the filter, or making the grind FINER or both
Mar 08, 2011 | Coffee Makers & Espresso Machines
We've had the Rancilio Audrey now for a year and still not have had a perfect cappucino. 1. Milk. We use 3.5 dairy milk, cold before going under spout. 2. What is the middle (steam) button used for? ...
  1. That is the right milk. Use a thermometer with the milk.
  2. The middle button is used for steam. It engages the high themostat for steam.
    1. Slightly open the steam valve
    2. Turn on the middle button
    3. Keep the end of the steam wand slightly above the milk surface (0.5 mm) so the steam incorporates air into the milk. (Takes practice)
    4. Open the steam valve as the boiler heats up. (Takes practice)
    5. When the milk get to 74 C (165 F) immerse the steam wand into the milk and heat to 82 C (185 F)
    6. Turn off the middle button and shut the valve.
  3. For 90 ml of coffee, use 14 gram of ground coffee. The coffee scoop that came with the machine holds 7 grams of ground coffee as it comes out of a grinder (not packed). Tamp the coffee after it is in the sieve.
Jan 01, 2011 | Rancilio Audrey
Takes a long time to steam milk. water comes out of the brewing head while steaming milk
i'll preface this by saying i have never used a strarbux machine, but I have used dozens of others (daily habit for 18 years now)
when are you trying to get your steam (ie before or after brewing the espresso)
If you have been trying before, wait till after (if your machine does not let you turn off the espresso output then when the coffee starts to slow down (just past the peak of flow).
It should take only a few seconds to steam the milk. (also the closer to the surface of the milk that the steam is released the frothier the milk will get)
Nov 15, 2010 | Starbucks Coffee Makers & Espresso...
There is no milk coming out of the frothing part of the Delonghi Coffee Maker, it just makes a noise and steam comes out.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Extremely loud squealing noise during steaming milk
This could be blocked. The best way to clear this is to switch off the machine and see if you can dismantle the frother arm. Sometimes the arm will come off by unscrewing. If it does, wash it in hot water and washing liquid. If it doesn't come off try putting the frother wand into a mug of cold water and allow it just to steam the water.
Frother wands don't just steam liquids - they **** up liquid which can block the vents and the actual steam hole which this machines' problem sounds like it does have.
Apr 05, 2009 | Breville ESP8XL Espresso Machine
Steamed milk is not coming out
Clean the steam wand, it unscrews and needs to be cleaned, also, descale the machine once the blocked tube is cleaned. When milk dries it is like glue and clogs the steam wand. so clean it daily after use.
Also, I think you meant to say, steam for milk frothing is not coming out. If you meant steamed milk is not coming out, it's not supposed to do that. Some Saeco's can add an attachment called a milk island but not the magic comfort plus.
Mar 04, 2009 | Saeco Magic Comfort Plus Espresso Machine
Steam does not come out of steam pipe
If you wait too long after making the coffee, you will not have enough water left to make steam. Try to steam the milk immediatels after the coffee loses pressure.
Jan 16, 2009 | Spidem Divina De Luxe Espresso & Coffee...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
2,227 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
