Question about Toshiba Televison & Video
Toshiba 43s7da rear projection tv ... turn on the power and I just get alternate flashing red & green LEDs ... what could be wrong ? Thanks. Ed Donnelly
4 Suggested Answers
  • 65 Answers
SOURCE: power button flashing red
stk convergence packs may haqve failed in the dead short mode stk392-110 removing them from circuit may allow the set to turn on again good possibility do you know how to solder?
Posted on Dec 09, 2006
SOURCE: Akai PT4298HD Rear Projection Television Problem
My AKAI 42 rear projection self focus set has blue shadows on everything and too much red, I cant seem to adjust it and self focus does not help?
Posted on Mar 23, 2009
SD Tech
  • 14553 Answers
SOURCE: Toshiba 51HX93, rear projection T.V. Green convergence problem
You will need to change both of the Convergence IC's----if you go to the trouble to just change one the other will fail in a short time---what happens most of the time is the white heat sink grease that was applied to the back of the two chips has dried out and one gets too hot and fails.
Most of these sets use 2 STK-392-110; WITH THE BACK OFF use a flashlight and you should be able to see the number on them; they are located on identical metal heat sinks with fins.
If this has been helpful I would appreciate a vote from you here. If you require more assistance respond to this post and I will help.
Posted on Aug 17, 2009
Red bulb nt working in model 43s7da
CONVERGENCE PROBLEM, FIND HONEST TV TECH. MAYBE A $300 REPAIR
Nov 11, 2013 | Toshiba 57HX81 57" Rear Projection...
I have a Sony Grand WEGA KDF-50WE655 50-Inch LCD Projection TV and when I turn it on the screen stays black and the green light flashes for 20-30sec then the TV turns itself off and 2 red solid lights...
The tv projection Lamp inside the tv now has it been inside this tv like 1 1/2 or 2 years already and tv is on and used it like 4 or 5 hours every days?Yes,the tv now the 2 red LEDS solid lights apear.One of those light have a word "Lamp" written on it bazel frame?Yes,100% ur tv projection Lamp life are over and ending.Tries websites like Ebay.com,Partstore.com to buy a new tv projection Lamp for the replacement.
Jul 18, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Green leds turn on momentarily when first plugged in then shutoff
ok , on hitachi pro tv is very common with bad power supply u may want to replace the voltage regulator which is next to the fuse u already replace , also loose connection on all the power supply seccion , also u may want to check the resistor close by the convergence ic 2.2 ohn if this are smoke replace stk392-110
May 07, 2009 | Hitachi 50SBX78B 50" Rear Projection...
48 inch toshiba with color alingment problem
Hello:
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Televison & Video
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba TP61F80 Projection TV
Check power supply for open micro fuse{s}-- If the fuses for the convergence circuits B+ are open,replace convergence IC,s and fuse devices.Then perform re-alignment in servicer mode.test run.Don't forget--PVAT! solder any/all bad connections.
Sep 28, 2007 | Toshiba TP61F80 61 in. Rear Projection...
Televison & Video Logo
144 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
