Gateway GM5048 3 long beeps with no video? Intel Desktop MB E210882. Any advice?
    President:
  • 1,996 Answers
Take a look at these links. They'll help you to interpret your bios beep error codes, and sort out the problem with your system...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 17, 2009
After starting the computer i amgetting 3 long beeps and no vedio.
an u help me
Posted on Aug 21, 2009
Intel p4 e210882 vgadrivers
Hello there!
You can go to Gateway page, and download all drivers for these particular board. its that simple!
Carl
Mar 04, 2014 | Gateway Intel E210882 4000762 Aa...
Motherboard
Is there any fan noise or beep codes or any sign its powering up>
check to see if the powersupply comes on with fan..then chk for processor fan and video next.
most gateway have OEM power connection that is not compatible with other supplys
chadman
Dec 24, 2013 | Computers & Internet
What is the max memory that i can install on an intel motherboard e210882
The Dell E210882 system board is compatible with PC2-3200 (400 MHz) or PC2-4300 (533 MHz) DDR2 non-ECC and unbuffered SDRAM. The motherboard has four slots for memory. Capacities compatible include: 128 MB, 256 MB, 512 MB or 1GB. The maximum installable RAM is 4 GB.
let me know if it helps you : ) replay to me as soon as you solve your problem : )
Sep 15, 2011 | Intel Motherboard
Where to get replacement motherboard for Gateway 507GR Intel E210882 LGA 775 GW149671509FC00124
I think a micro atx socket 775 motherboard would work here if you wanted to retain the original CPU
You may have to sort out some wiring though..
For an original board, best off trying ebay
Jan 27, 2011 | Gateway 507GR PC Desktop
Maximum ram capacity for the board
You can look it up at this site: http://support.intel.com/support/motherboards/desktop/d865gvhz/sb/cs-010872.htm
but I believe it will be max. 2 GB per slot(DIMM)'s, so depending on the no. of slots on your MB x 2 will be the max. RAM capacity................sodeep
Jul 26, 2009 | Intel Motherboard
Can't find a manual for Gateway GT5428 motherboard
I believe that is a pci express slot (x1)
Here is the manual for your motherboard:
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Jun 28, 2009 | Gateway GT5428 PC Desktop
3 long beep
The Intel motherboard D845GLVA can only run up to 2GB of 184-pin, 2.5 V, DDR266/200 MHz SDRAM. Test the system by inserting only one stick of memory into slot 1 which is closest to the CPU. Boot system & listen for beep code. If no change remove memory & insert into slot 2 & boot system. Listen for beep code. The Intel D845GLVA MB uses the AMI bios. There is no code to match your 3 long beeps.
Click on the link below, scroll down to AMI;
http://www.computerhope.com/beep.htm
However, you mentioned you loose display when you here the 3 beeps. This is common when a video card is not connected correctly or does not have enough power. Since your MB uses a built-in video card it is very possible that the video controller,
Intel 82845GL Graphics and Memory Controller is going. You can test this theory by buying a PCI video card & installing it into any one of the three PCI slots on the MB. You will not need to enter the MB bios to make any changes. The MB will auto detect the video in the PCI slot & use it over the built -in video. See page 15 in your manual: PCI Auto Configuration.
If you need the manual for your MB you can download it from Intel.
Click on the link;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=947&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Any one of the video cards listed on the next link will run in your system;
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=319&name=PCI-Video-Cards&
Mike
Jun 18, 2009 | Intel Desktop Board D845GLVA...
Drivers for window 98 for intel desktop board e210882
Here is the Intel site. http://www.intel.com/support/motherboards/desktop/index.htm?iid=mbd_body+dt_mature You will have to look around for the downloads. You will need the model of the computer to be able to find the drivers..
Jun 06, 2009 | Gateway 310 X (310XSP) PC Desktop
No video e210882
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
alkllklju15
Apr 12, 2009 | Dell (E210882) Motherboard
I bought a mother board from a swap meet but it didnt come with the wiring up diagram and im lost as to how to wire it up only for the power reset etc.. not sure which way they plug into i think i have...
Hi kjstenny, not sure where you saw the board E210882. This is not a valid Intel model number. The Intel D865GLC is a valid model number & you can download the manual for this at the link below:
http://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
Main Intel link for D865GLC:
http://support.intel.com/support/motherboards/desktop/D865GLC/LC_manual.htm
MB layout page 14 & 15. Than see page 13 block D, J9J1 Front panel pins. Page 43 for jumper connections.
Intel D865PCD (Matched). Front panel, page 34 & 35. Download manual at this link:
http://download.intel.com/support/motherboards/desktop/d865pcd/sb/cdenglish.pdf
Main link: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1671&lang=eng
Intel D865PCK - (No Match). (Or no longer listed).
D865PE50 - (No Match). (Or no longer listed).
The most common wire color for each 2-pin connector will be negative, including the color black.
Good luck kjstenny!
Still need help, just post your question.
Mike
Dec 03, 2008 | ASUS A7S333 Motherboard
Computers & Internet Logo
1,179 people viewed this question
David Payne
David Payne
