Question about Mitsubishi VS-60603 60" Rear Projection Television
My Mitsubishi VS6043A is blurry
It has been blurry for some time now, I wondering if there was a fix for this.
    President:
  • 512 Answers
The problem is in the convergence section of the tv. A solder joint or loose connection somewhere in the convergence circuitry.
Try the Whack Test: When you first turn the set on and you see the bow-tie shape just vigorously whack the cabinet with your hand or fist. Whack it on the sides, top, back, etc. to see if the vibration from your whacking will wake up the bad connection or cold solder joint. If you can see a change in picture then it is a loose solder joint. Very costly to repair, over 10,000 solder joints in a tv.
Posted on Jul 17, 2009
Visuals look like color is displaced and slightly blurry... fix?
Not worth fixing. This has picture tubes that are expensive to replace. To repair this requires way more expertise than can be communicated via fixya. Your money would be better spent on a new TV
Jul 12, 2015 | Mitsubishi Televison & Video
Blurry picture
convergence problem...very common. An excellent TV, well worth repairing!
Jun 03, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My picture is blurry, re-setting the convergance helps
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Mitsubishi WT-46807 46" Rear Projection...
THE PICTURE GET BLURRY FOR A FEW SECOND THEN GOES BACK TO REGULAR..IT IS A 55 INCH MITSUBISHI TV REAR PROJECTION...IS TIS EXPENSIVE TO FIX?
Yes,the shop will cost u $300 for parts and labors. Convergence problems,the 2 convergence ICS it well die,just not dead yet.Problems will be blurry,color misalign,3 D look,when the 2 convergence is dead.
Feb 06, 2010 | Televison & Video
Blurry mitsubishi projection VS 5041
there a one or more defective tube needs to be replaced is typical efect when is tube end of life.
Jan 02, 2010 | Televison & Video
Blurry screen double vision picture
The convergence circuit has failed. It is not a easy fix due to the tear down needed to get to the circuit area. I would call Mitsubishi at 18003322119 to get a Authorized Service Facility to check it out and give you a estimate of repair cost.
Jun 22, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Blurry GE 27GT616 need help on how to
The problem could be with your crt base socket, if you know how to solder well and can identify the components and have a knack in dealing with the internals you can fix this yourself. Base socket is the stuff that you connect to the narrow end of the picture tube, you will find a pcb and a plastic connector almost round in shape on that board. Desolder the socket (the plastic connector) and get a new one, exactly the same type and solder this back.
Jan 30, 2008 | GE 27GT616 27" TV
Mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Nov 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Help: My tv picture has started going blurry
The picture tube is going bad,not worth repairing,better invest in a new set. The rating response is important to the person helping you.
Oct 11, 2006 | Samsung TXN2734 27" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
