Question about Whirlpool LSR6232J Top Load Washer
The Only Thing The Agitator Agitates Is Me
I believe that I overloaded the tub can over stressed the gearing in the top portion of the agitator. It no longer "agitates"; just makes clicking noises.
  • Anonymous Dec 27, 2007
    I would like to get inside to replace a part
  • red49 Jan 08, 2008
    seems like it wont agiatate... if fills up with water, then I hear a noise like it wont agitate
  • 213 Answers
Your right. the parts you need are called dogs. they com in a set of 4. replace all 4 at the same time
Posted on Nov 20, 2007
Top half of agitater isn't engaging right. It's loose, and won't tighten anymore with top bolt. Can a spacer be utilized under top bolt head, or is gear probably shot?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Feb 13, 2011 | Washing Machines
The upper portion of the agitator is not connected and spins freely.
Dec 11, 2010 | Washing Machines
The agitator doesn't rotate aggressively. I popped the center cap and it appears that the plastic paws have broken partially off and are not engaging the geared ring, but rather just slipping over it.
Dec 06, 2010 | Washing Machines
The agitator in the middle of the basket is freewheeling the "dogs" don't catch it. The basket agitates and spins, but the thing in the middle will only do its job when I push it down. Help?
Nov 17, 2010 | Kenmore Washing Machines
The top/ spiral portion of my agitator is not moving as I think it should. Is that the DOG TEETH? looking inside the top I can see some worn gears. Please tell me this is a cheap easy fix.
Jul 31, 2010 | Washing Machines
Top portion agitator not working - Kenmore 110.27812692
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27812692
Apr 27, 2010 | Kenmore Washing Machines
The agitator (upper portion) will not spin. If I
Mar 02, 2010 | Kenmore 22422 Top Load Washer
Top half of the agitator does not move during wash cycle. bottom half works OK. 90 series Kenmore. pop the cap off the agitator top, and find 4 cams that come out and touch the geared wheel but do not...
you can replace them ,they are called dog ears, can get from your nearest appliance shop or you can order from Repairclinic.com, not a hard job to replace ,repair kit is about 15.00 bucks
Jan 30, 2010 | Kenmore 23822 Top Load Washer
The top portion of the agitator is not working
Also see the following for an illustrated description of the above.
Dec 20, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator won't agitate
Replace what is called the dogs in the agitator (part number 80040? i think)
Oct 29, 2007 | Roper RAS8244KQ Top Load Washer
Whirlpool LSR6232J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
