Question about Microsoft Windows Server Standard 2003 for PC
How can I mount an IBM AIX hard drive in Windows?
IBM AIX (5) Server experienced a Hardware Crash, and I'd like to recover data directly from the hard drives. I moved the SCSI drives to a Windows Server, but they show up as "Unpartitioned Space". Can I somehow "mount" the AIX File System in Windows to recover files, or is there a Windows based utility that will allow me to view and recover files from the AIX drives?
  • cutterchrist Jul 27, 2009
    Thanks for the response, JaxPlanet. I was actually able to recover what I needed with a product called EnCase. It is a forensics based recovery system that supports all known file systems, including JFS2 in my case. It's very expensive, but if you're in the recovery business, I'd have to say that it's a "must have", and I can also tell you that it'll pay for itself the first time you have to use it.
  • labtech Feb 05, 2012
    I reviewed this info about Encase you were describing. Are you sure you were able to recover the files using Encase? My research led me to believe that you can only view the files.
    Can you confirm one way or another, please?
  • 922 Answers
AIX uses a file system that is not supported by Microsoft Windows. Most likely you will need another AIX system to read the file system. I recommend that you contact a hard drive recovery service like Ontrack Data Recovery and get some guidance.
You should remove it from the Windows computer ASAP. Windows has the habit of making changes to any disk it sees and you may lose everything!
I hope this helps.
Posted on Jul 24, 2009
Power accidental problem and windows computer corrupted
Ask your oem (manufacturer) whch button to press on startup to access your windows recovery.. Ask them how to perform the recovery as well.
May 15, 2014 | Microsoft Database Software A5K-02817 SQL...
Can i install windows server 2008 on 7026-H70 IBM
perhaps its only running UNIX operating system, AIX? ie it doesnt recognise windows
May 07, 2014 | IBM RS/6000 7026 - H70 (7026-H70) Server
Hi, within the previous 12hrs my e-series server bombed out - there are two issues (1) Memory DIMM malfunction (2) serveRAID-7k error 2807... I removed the faulty memory DIMMs, but the RAID error still...
You can recover RAID data from hard drive with RAID recovery software easily.
Tenorshare Data Recovery Enterprise is a comprehensive data recovery software that supports RAID recovery for RAID 0 and RAID 5. Lost data in RAID 0 and RAID 5 can be deeply scanned and restored immediately. Meanwhile, files and folders in RAID 0 and RAID 5 can be copied to other partitions directly. http://www.any-data-recovery.com/product/datarecoveryenterprise.htm
Aug 29, 2011 | IBM ServeRAID-7k Controller (71p8642) SCSI...
I cant open or format my hard disc
Try this method
Uninstall the hard disk
Connect it to the other system/laptop as external drive
Install data recovery software on system/laptop
Scan the external drive for recovery options available
Save the data you want to recover
You can download a good data recovery software from http://www.windowsdatarecovery.com/
Aug 16, 2011 | Computers & Internet
Hitachi hard disk model no. Dk23ba-20 crached. it isnot working. is theire any way to make it workable.
It depends on your definition of "crashed" -- if it still spins and works, but the copy of Windows stored on the disk no longer successfully boots into Windows, that's one type of "crash",
and you can recover (by reinstalling Windows).
If it does not spin, or nothing can be read from the disk, that's another type of "crash",
and it's usually a "fatal" problem -- the hardware will never work again.
However, there exist professional "data recovery" services, that can repair your disk-drive,
just long-enough to _once_ read your files and copy them to a new disk-drive.
Example: http://www.seagate.com has "no-charge-if-we-cannot-recover-your-files".
Nov 06, 2010 | Hitachi (DK23BA-20) 20 GB Hard Drive
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
Procedure to install ibm aix operating system
Hi
Which OS installed tell me then i ll try to solve
Harry
Apr 20, 2009 | Microsoft Windows Server Standard 2003 for...
Can I install Windows Server on IBM RS/6000 51A Server ?
No. The IBM has a RISC processor and Windows only supports Intel or AMD. It does support some versions of linux if you want a GUI interface. :-)
Regards,
Daryl
Jan 14, 2009 | IBM RS/6000 9.1GB DASD FEATURE
Raid 5 failure
to recover your data is very easy. just slave your hdd to a system that is working fine and switch it on.after windows has succesfully loaded go to my computer you will see to hard drive.the slave hdd will be labelled B.double click on it go to my documents and copy all your filesand save it on your working hard drive.after copying make sure you remove the slave hard disk
Jan 31, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
863 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
