Question about Durabrand DUR7 Portable DVD Player
Portable durabrand dvd wont read disc
Durabrand portable dvd do not read dvds (disc not valid)
  • 3,866 Answers
If it is reading a burned movie from the internet make sure you set you brun software for captability mode.
If this is a orginal disk make sure its free of dust and scratches.
1. buy a lens cleaning kit from walmart or any other eletronics store.
2. Make sure the disc is free of scratches.
3. change disc's and see if it works on any others.
if these steps do not help then the laser would need to be replaced. Durabrand is a Wal mart brand i had mine for 2 years and i had to clean the lens 3 times with a cleaning kit.
Thanks
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 17, 2009
Hi I need region free for dur 7dvd portable thanks
Posted on Jul 23, 2009
SOURCE:
Doesn't play any dvd or cd
you need to see if the disc is spinning inside the unit, if it is then you need to either clean the laser with a clean cotton tip or replace the laser, if the disc doesnt spin, it may be the spindle motor(held within laser assy,which is easier to replace) or it could be the mpeg printed circuit board. Good luck.
Sep 26, 2009 | Durabrand DUR7 Portable DVD Player
After loading it reads no valid disc
Either the laser lens eye is dirty and needs to be cleaned with rubbing alcohol and cotton swab or the lens unit is faulty and will need to be replaced
Aug 01, 2009 | Durabrand DUR7 Portable DVD Player
Displays "No Disc"
It can be several reasons
1. Disk is upside down
2. Lens is durty. CD/DVD cleaning disk will help
3. Disk is in different formate (for instance NTSC for US but you trying to playback disk in PAL)
4. Disk has different region code (look is the dvd player and disk have the same code, or ALL Regions code)
Good Luck
Dec 26, 2008 | Durabrand DUR7 Portable DVD Player
Pvs1371
I could walk you through a list of tests, but the truth is the unit will need service. The good news is, you can now contact Durabrand and get the tests directly from their website. Please click on the link below:
Durabrand Technical Support, Parts and Accessories
http://1800customersupport.com/
If you require any additional assistance do not hesitate to click on the "ASK ME" button and I will respond to your request as soon sa I can.
Oct 06, 2008 | Durabrand Portable DVD
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
Durabrand portable dvd player dur-7
Duarbrand portable DVD players are no longer supported by Walmart because the company contracted to manufacture them is no longer in business. Ripoffreport.com has several complaints on the product line. Walmart has been exchanging the item.
Jun 28, 2008 | Durabrand DUR7 Portable DVD Player
Durabrand DUR-7 portable DVD player
Most DVD players that would display such a message even with a known good disc inside signifies that the that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 10, 2008 | Durabrand DUR7 Portable DVD Player
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
DVD cannot read DVD's anymore
Have you tried cleaning lense with soft cloth and alcohol? Sometimes cd or dvd cleaners do not work well for some systems.
Aug 30, 2007 | Durabrand DUR-1700 Portable DVD Player
No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
Apr 16, 2007 | Durabrand PVS1966 Portable DVD Player
Durabrand DUR7 Portable DVD Player Logo
429 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
