Question about TruTech PLV16320 Television
Can I mounted on the wall? - TruTech PLV16320 Television
  • TruTech Master
  • 3,866 Answers
You can mount almost any LCD on the wall they even have universal mounting kits for hard to mount displays so yes you can mount this on the wall with no problem.
Thanks
Rulds2008
Posted on Jul 17, 2009
How do I install a tv on my wall
First of all find out what size mount is on the TV. On the back of the TV you should see 4 screw holes to take the bolts of the stand. You can measure the space between the holes. Then you can search for a mount that will take that size. If the TV is big you will need a very strong wall mount.
When you get the mount it should have instructions for mounting it. But make certain the wall you are fixing it to can take the weight and is stable. Fix the mount to the wall, make certain that you use the correct screws and plugs for the screws. You should be able to tell if the mount is secure enough. If you have any doubts, get somebody in to do it. The mount will come with the correct fixing screws for the TV. You will need two people at least to fix a smaller TV to the wall and two people to hold a big TV while a third screws the mount to the TV.
Feb 10, 2017 | Televison & Video
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
Is there a specific wall mount for this TV to swival in all directions
Acquiring wall mounts for television are according to preferences. For example, wall mounts that provide the TV dynamic directions to suit operators requirements would have separe requirements. The multidirectional wall mount provides the TV capability to swirl around several angles. Howeever, acquiring wall mounts as requirement to encamp the TV also placement on safe areas from which the device is observable is an alternative considerations. TV wall mounts provide multi purpose functionalities. For example, TV wall mounts that provide both encampment housing placement hinging to an area, and finallly capable of multidirectional functionalities available for acquisition at retails. Also possible are acquisition of customisable wall mounts to suit the type of placement area required on TV sets either suitable at various locations. For example, TV wall mounts are customsiable to house sets that require functionalities with complimentary devices like decoders, modems, DVD players, VCR recorders, or cable wiring. The process of acquiirng wall mounts is achieving interhrety of the TV set, housing available devices requiredm and achievifn viewer egonormics. Consult room device area estimate expert before acquirng wall mount to ascertain the appropiate conditions capable of providing egonomic experiences. Goodluck
Jan 08, 2011 | Televison & Video
Can i mount my tv on the wall it is model cwf32l6
Yes you can.
there are many types of wall mounts you can buy. Ensure the load / weight rating of the wall mount exceeds that of your TV, and mount it exactly as per the manufacturers instructions.
Most audio visual shops sell all types of wall mounts.
You can also check out ebay.
Feb 28, 2010 | Symphonic ST419E TV
I NEED A WALL MOUNT FOR A 32" tv
Wall mounts use standard mounting configurations, you should be able to get a wall mount for a 32" flat panel TV at any local electronics store.
Jul 30, 2009 | Element Electronics Televison & Video
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
Mounting under flat screen tv
There is no wall mount bracket for the VCS-10. It was not designed to be wall mounted. Your best solution is to mount a 22"x8" shelf to the wall 4-6" below the TV. Make sure it is mounted sturdy enough to support 10lbs.
Sep 05, 2008 | Bose VCS-10 Center Speaker
Wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Jun 28, 2008 | Televison & Video
TruTech PLV16320 Television Logo
73 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
