I have a Kenmore Series 80. It works, but I have to manually change cycles. It will remain on the current cycle until I move it. Could it be the lid switch? Timer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer: http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd alto look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
