Question about Foxconn 6627MA-RS2H Motherboard
Cpu support i wanted to know whether this board foxconn n15235 supports core2 processor with regards Shaji joseph
  • 374 Answers
An attractive value of dual core processors is that they do not require a new motherboard, but can be used in existing boards that feature the correct socket. Check sockets if same then enjoy. I don't think that you motherboard supports Core 2 CPU,but you can't neglect the chances.Before buying ask the retailer about the sockets matching.
Posted on Jul 17, 2009
Why my foxconn g41md -v motherboard does not support core 2 duo processor
It does support a core2 duo up to quad core but they have to be 1333fsb (front side bus). I suspect you have an early model of the cpu which isn't compatible with the 1333fsb such as a 670fsb. If you look at the back of your CPU you will see the model number. Google that and see the results. You will need to upgrade your CPU.
Apr 04, 2014 | Foxconn G41MD Core 2 Quad Intel G41 DDR3...
Joe covette
I understand, and I appreciate your looking deep into both CPU's.
Are we talking about,
1) Intel Core2 Duo E6550, which has a maximum frequency rate, ('Speed'), of 2.33GigaHertz?
http://en.wikipedia.org/wiki/List_of_intel_core_2_microprocessors#.22Conroe.22_.2865_nm.2C_1333_MT.2Fs.29
4MegaByte of L2 Cache, 1333MegaHertz Front Side Bus?
(4MB L2 cache / 1333MHz FSB)
Based on the Conroe Core technology, and the 65nanometer architecture? 0.85Volts to 1.50Volts - voltage range?
2) Intel Core2 Quad Q9550, which has a maximum frequency rate of 2.83GHz?
http://en.wikipedia.org/wiki/List_of_intel_core_2_microprocessors#.22Yorkfield-6M.22_.2845_nm.29
2 times 3MB of L2 Cache, 1333MegaHertz FSB, Voltage range - 0.85 Volts to 1.3625 Volts?
Based on the Yorkfield-6M Core technology, and the 45NanoMeter architecture?
Don't know.
I just look at what motherboard chipset is used, then if it will support both a Dual Core, and a Quad Core; I look at the voltage range, and core technology/architecture.
http://www.fixya.com/support/p929676-gateway_gt5692_desktop_computer
So we are talking about a Gateway GT5692?
http://support.gateway.com/s/PC/R/1015553R/1015553Rnv.shtml
Components > Motherboards > 4006272R - Foxconn (Bengal) RS780 Motherboard > Specifications,
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rsp2.shtml
Ha! So we are NOT talking an Intel CPU! (Processor)
Apparently not discussing a Gateway GT5692 Desktop PC, either.
What desktop computer are we talking about Virgil, and what is the motherboard chipset?
Regards,
joecoolvette
Apr 21, 2013 | Gateway Computers & Internet
My core 2 duo E6550 does not work on my foxconn g41mxe motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186187
Motherboard supports Processors with a Front Side Bus (FSB) of either 800Megahertz, or 1066MHz.
1333MHz FSB support is done with OVERCLOCKING.
http://ark.intel.com/products/30783/Intel-Core2-Duo-Processor-E6550-%284M-Cache-2_33-GHz-1333-MHz-FSB%29
Intel Core2 Duo E6550 processor has a 1333MHz FSB.
http://www.manualowl.com/m/Foxconn/G41MXE/Manual/297328
I reduced the view size to 120 percent. Go to Page 27.
Press DELete key to enter BIOS Setup.
Use Down Arrow key to highlight - Fox Central Control Unit
Press the Enter key
CPU Frequency Setting should be set to 333 (333MHz)
Intel processors are 'Quad Pumped'
333MHz x 4 = Approximately 1333MHz. (1332)
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20775&model=G41MXE&cputype=Intel
Note the version of the BIOS program also.
Regards,
joecoolvette
Sep 25, 2012 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
Characteristics of n15235 manual motherboard
- Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
Also, if you need drivers for all that components, use this tool: http://tinyurl.com/n8nrz6t.
regards
Sep 16, 2011 | Foxconn 6627MA-RS2H Motherboard
ONN N15235 motherboard, which is a 775 socket. I am currently running a Pentium E2160 on its but its pretty slow so I bought an E5400 to replace it. When I changed the CPU over and started up my computer...
The LGA 775 processor socket doesn't matter, calderwooddu.
It's up to the motherboard chipset, and the BIOS program, and version, of what that Foxconn N15235 will support. I would go back to the Pentium Dual Core E2160, use CPU-Z from CPUID.com, (Free), and see what the motherboard chipset is, first.
(Motherboard chipset: The Northbridge, and Southbridge chips. Chip is slang for I.C. Integrated Circuit)
The Northbridge chip is what determines what Processors are supported.
1) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
2) http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Since the E2160 is built upon the 65nm technology, and the E5400 is built upon the 45nm technology, the Northbridge chip of the Foxconn N15235 may not support the E5400.
With the technology change are also Instruction Set changes. Plus other parameter changes. The BIOS program, and version on the Foxconn N15235 may not support these, either. Sorry to be a bummer.
Not a solution per se, Yet.
Need to know what computer this Foxconn mobo is out of. (MOtherBOard)
OR, if you get the computer operational again, let's use CPU-Z to see what the motherboard chipset is.
Need help in downloading, and/or installing CPU-Z, post in a Comment.
Oct 09, 2010 | Computers & Internet
Where to free download matherboard winfast n15235 driver
Here is a link:
http://www.foxconnchannel.com/support/downloads.aspx
The problem is that the N15235 is not the model of this motherboard. It turned out to be the Foxconn 6100M2MA-RSH2.
Kind regards and please post if you need further assistance
Feb 26, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
The motherboard foxconn n15235 its compatible with processors intel core2 duo and intel core2 quad?
Then email or contact foxconn and request a spec printout of what processors will run with their board.
Nov 27, 2009 | Computers & Internet
Is it support pentium 4 for foxconn motherboard n15235
This is a socket 775 boards and it should support Pentium 4 processors. TC
Mar 24, 2009 | Computers & Internet
Foxconn manual for a n15235
There is no Foxconn mainboard (and will never be...) called N15235 although this is printed on the board. The right name is P4M800P7MB-RS2H and you can find all stuff here: LINK
P.S.: you can find the right model number printed on the board beside the RAM slot near the CPU and on small label above.
Tom (mailanmeyer@gmail.com)
Feb 18, 2008 | Computers & Internet
Foxconn 6627MA-RS2H Motherboard Logo
453 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
