Question about A4tech KBS-720 Anti-RSI Keyboard
The number keys doesn.t work properly: `1 `1 2(f1) 3 54 54 67 67 =8 9 -0 -0 =8.. that should be: ` 1 2 3 4 5 6 7 8 9 0 - =
    Sergeant:
  • 193 Answers
Sound's like dust is the issues here, so you will need to remove the keys that you are having trouble with or all keys to be on the safe side, once removed get a damp cloth and clean the keyboard where the keys once were and while your doing that soak the keys in some water to clean them up and dry them when done. Put keys back into place and test keys to see if problem as gone or not. Hope this helps.
Posted on Jul 17, 2009
Ford focus 2001 1.4cl key fob not working
Is it your original key fob or a new one?
Jun 26, 2013 | Cars & Trucks
2007 VOLVO S60 2.5T, KEY DOESN'T TURN PAST POSITION #1?
wiggle steering wheel, step on the brakes, wiggle the shifter see if any of the safety interlocks are not working properly.
Feb 09, 2013 | 2007 Volvo S60 2.5T
Key doesn't open door
Your key may be getting worn. Since you cannot get a key cut properly by using a worn key, go right to the dealership with your ownership papers and vin number, and they can follow a code to have a proper key cut for you. Best thing to try for $3 Hope this was helpful
Jan 27, 2013 | 2006 Subaru Forester
My p.c keyboard doesn't work propely
Hello
The keybpar pad should be replaced. Just contact the authorised service center to get it replaced. A very skilled work indeed.
Feb 26, 2012 | Sony PCG-FRV3 Notebook
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
My dell latop k\b some of the keys are not working.
Pick up a can of compressed air (called Duster at most hardware stores) and try blowing out the keyboard. If that doesn't work, you can pry off the keys using a butter knife or a screwdriver (careful not to break the hinges) for the keys that are not working to see if you can find anything keeping the key from being pressed down (NOTE: Even hair is thick enough to mess with the keys), if that doesn't work I would suspect a problem with the keyboard. You can take it into a repair facility for a proper cleaning for a small fee, but you may need to get a replacement keyboard and install it. You can find them on ebay all day long if you search for your model number, or you could go through dell.com. Just be sure to contact the seller (if using ebay) to ensure that the keyboard you want to buy is compatible with YOUR model of computer, if not usually they'll suggest one that is.
Tj
Jul 20, 2011 | Dell 0Y3740 Keyboard
THE REMOTE STARTER DOESN.T WORK AT ALL. tHE STARTER DOESN;T WORK OR THE ALARM OR OPENING TRUNK OR EVEN LOCKING OR UNLOCKING THE DOORS. i RECENTLY GOT A NEW BATTERY FRIOM THE PONTIAC DEALER HOPING TO FIX...
have you checked if the battery is placed properly in the key.when you press the remote alight on the key should glow.if not so then check the key battery.if fine then the cause is elsewhere.
Jan 02, 2011 | Pontiac Grand Prix Cars & Trucks
Keybord problem
I suspect someone at some time has spilt water on it and corrosion has set in you will need to have someone remove and clean it or fi a nnew one
Aug 06, 2008 | Computers & Internet
Sharp Fax machine - UX-B700
Try this:
Set the fax machine to AUTO reception. Next, you would want to set the proper settings in your Option Set List. To print a list press the FUNCTION key, the number 2 key, then press the # key until it reads OPTION SET LIST in the LCD screen and press the START key. This will print your list. The following settings should be seen: Number of Rings 1 to 4 rings (setting #2) Dial Mode- TONE (setting #8) TAD Connected- OFF (setting #9) * Quiet Detect Time- 04 seconds (setting #10) * Distinctive Ringing- OFF (setting #12) **
Let us know if this doesn''t fix it... we can go from there!
Maggie B
Feb 24, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
A4tech KBS-720 Anti-RSI Keyboard Logo
353 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
