Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
Steering wheel change
I was wondering if there is something special i need to do to change my jeep TJ steering wheel so the airbags don't go off?
    Sniper:
  • 59 Answers
Yes,just disconnect the battery terminals and once you remove the airbag cover locate the power plug that goes to the airbag and disconnect it.Make sure you have replaced everything and everything is tight before reconnecting the battery.Rate Me FIXYA! if it helps.
Posted on Nov 18, 2007
How to replace a multi-function switch.
Not very. It requires, in most cases, the removal of the steering wheel and airbag assemblies. There are safety issues in messing with the airbags, and you need special tools to remove the steering wheel and the additional hardware behind it to get to the multi-function switch. And then the wiring harness for it must be correctly routed down through the steering column or you can wind up with frayed wires and short circuits.
Dec 22, 2015 | 1993 Chrysler New Yorker
Air Bag light on, '99 Jeep Gran Cherokee
When the airbag light (SRS) is on or blinks it means a fault has occurred in the system and the airbag diagnostic monitor has disabled the system, the most common problem that turns the light on is a break in the connection to the steering wheel mounted airbag, this is due to a rotating ribbon contact that breaks under the steering wheel that connects the airbag to the wiring harness and the diagnostic monitor, the part is called the clock spring contact, a coiled up ribbon electrical contact that turns with the steering wheel while maintaining a mechanical connection to the airbag mounted on the steering wheel, to replace this part you must disarm the airbag system and remove the steering wheel, this requires a special steering wheel puller tool and that you disarm the airbag system before you start the work, to do this disconnect the battery negative cable for 1/2 hour prior.
Oct 20, 2011 | Cars & Trucks
I have a '93 jeep cherokee and my horn doesn't work. I've checked the fuse and it's fine but now i don't know where to locate the horn itself to check for disconnections or to replace...
LOOK UNDER THE LOWER AIR DEFLECTOR FROM BELOW THE RADIATOR. IF YOU HOT WIRE CAR HORN AND IT WORKS.YOU HAVE TO REPLACE THE WHOLE AIRBAG IN STEERING WITH HORN CONTROL BUTTONS.YOU NEED TO DISABLE AIRBAG IN STEERING WHEEL WHEN REPLACING AIRBAG AND HORN CONTROL BUTTON PAD.JUST TURN OFF RADIO FIRST, THEN DISCONNECT REMOVE THE NEGATIVE BATTERY CABLE.WAIT 20 MINUTES BEFORE WORKING ON AIRBAG AND HORN PAD IN THE STEERING WHEEL.
Aug 12, 2011 | Jeep Cherokee Cars & Trucks
My 96 jeep cherokee has a turn signal problem. My dad said it is the cluster in the wiring in the steering wheel. Have you heard of this and if so what do i do. Do i have to buy any parts?
generally there is a multi-function switch underneath the steering wheel. you must remove the steering wheel which requires a special tool, and some expert training to keep the airbag intact. you replace the switch and reinstall the steering wheel. not user serviceable issue.
Sep 15, 2010 | 1996 Jeep Grand Cherokee
Removing the steering off an fg falcon?
You actually need special tools to do this which only a Ford dealer would have at the moment.
The airbag system or SRS needs to be disabled before you can remove the steering wheel airbag module.
Sorry mate thats the only option you have.
Thanks
Jason
Jul 15, 2010 | 2007 Ford GT
1998 jeep air bag light came on
When the airbag light (SRS) is on or blinks it means a fault has occurred in the system and the airbag diagnostic monitor has disabled the system, the most common problem that turns the light on is a break in the connection to the steering wheel mounted airbag, this is due to a rotating ribbon contact that breaks under the steering wheel that connects the airbag to the wiring harness and the diagnostic monitor, the part is called the clock spring contact, a coiled up ribbon electrical contact that turns with the steering wheel while maintaining a mechanical connection to the airgag mounted on the steering wheel, to replace this part you must disarm the airbag system and remove the steering wheel, this requires a special steering wheel puller tool and that you disarm the airbag system before you start the work, to do this disconnect the battery negative cable for 1 hour prior.
Dec 29, 2009 | 1998 Jeep Cherokee
Airbag light is on and was wondering if i could get location of sensors and if there is some kind of reset switch.
Dec 15, 2009 | 2003 Toyota Tacoma
Chime/buzzer going off behind passenger airbag 2001 Cherokee
hellow from california,it sounds like the clockspring in the column, something you probably dont want to fix yourself unless you have airbag protetcion insurance.
Jun 12, 2009 | 2001 Jeep Cherokee
Airbag and buzzer on in jeep tj 2002 how do i
you need a professional scan tool to acess the airbag and get the codes if the airbag light is on THERE IS A PROBLEM AND IT NEEDS TO BE FIXED a pro needs to look at this car
Apr 17, 2009 | 1997 Jeep Tj
2002 jeep grand cherokee
Basicly you have to take apart the steering column cover and the switch is held in place with screws.
If you have to take the steering wheel off, it is best done by a qualified tech. There is an airbag in the steering wheel that has to be disconnected. THIS AIRBAG CAN GO OFF, PLEASE DO NOT TRY THIS YOURSELF!!!!!!!
Sep 16, 2008 | 2002 Jeep Grand Cherokee
Car Audio & Video Logo
78 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
