Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Powers off and red light flashes 4 times - Panasonic PT-43LC14 43" Rear Projection HDTV
    Problem Solver:
  • 6 Answers
What should I do if the power indicator is blinking on the front of the TV? If the power indicator is blinking on the front of the TV, turn off the TV. Then unplug the power cable from the current power source and try a different electrical outlet. Also, remove the power cable from the rear of the TV and plug it back it in (the power cable tab is inserted correctly when you hear a click).
Posted on Jul 24, 2009
  • 100 Answers
Check the C945 transistor and diode which is connected to this transistor.
Posted on Jul 17, 2009
5 Suggested Answers
  • 5 Answers
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Posted on Sep 09, 2009
  • 39 Answers
SOURCE: Panasonic PT-50DL54J DLP. power light flashes red
sounds like lamp is dead
Posted on Feb 22, 2010
  • 5105 Answers
SOURCE: the power red light keeps flashing six times
The blink code means that something on the board is over current/over voltage. It could be an overload of the +5 line (A/B boards) or the +5 line is shorted.
The TV needs to be opened up and the boards checked. You may be lucky and only need a thermal fuse. Also check your bulb.
I hope this helps.
Posted on Apr 26, 2010
  • 4090 Answers
SOURCE: Will not come on. red light flashes 4 times
Never a good sign when you have red flashing codes
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Please rate my help++++Thanks for using FIXYA
Posted on May 28, 2010
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
The TV will not turn on. When the switch at the lower left corner is pressed the light in the switch flashs green for about 4 seconds as the TV seems to go through a start up procedure. Then the light...
The red flashing light is the service code. My guess is the power supply is bad now, but it could be something else. If the TV is under warranty, take it in and get if fixed. If it is not, then you may try to check the power supply first. Count the flashes of the red light and check online for the issues when this model flashes, 4 times or 6 times... or 9 times, etc.
Oct 10, 2010 | Panasonic TH-46PZ800U Plasma TV
May 28, 2010 | Sony KDS-50A2000 50" HDTV
Power Light Flashing Red
Change the lamp. If red led is flashing 4 times. replace lamp fan.
Apr 22, 2009 | Televison & Video
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Battery light flashes red 4 times
Check your users manual. Normally if it is blinking it is powering up, but may be different depending on model.
Jan 01, 2009 | Dell Inspiron E1505 Notebook
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
242 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
