#3 WILL NOT SELECT
Button #3 works in the second selection position as in 134 but will not work in the third selection position as in 143. The #3 will lock down on keyboard,but will not activate selection mechanism.This problem is happening on my Rockola 474 jukebox
  • donco902 Jul 17, 2009
    we have taken the switch assembly out of the jukebox and perfomed a resistance check thru the switch contacts to the end of the first wire conector. I had talked to the people I bought it from, they thought it could be a programming issue. I have since orderd all the manuals for the unit,but found nothing in them that applies to programming. The resistance thru the contacts and connector was at 5ohm or less.
  • 3,741 Answers
Check out resistance on all the other contacts to from the switch.that will give the exact idea.as under 5 is proper.but its lacking some power to function and give appropriate results.if its programming issue it will not work on other settings too. check out. thanks.keep updated.please do rate the solution.thank you for using fixya.
Posted on Jul 17, 2009
  • 215 Answers
Hi, Welcome to FixYa
I guess it's a ladder switch, there are three banks of buttons.
Take a Digital voltmeter and check the continuity between the contacts first.
I suppose, it's a "ladder switch circuit", and the problem(s) are in the # 3 button. If it is a "ladder" type
switch, check to see if when the # 3 button is "at rest" the
connections are made to the # 1, #2 switches.
You can go through the steps in the link if you want to open the turntable.
If you are satisfied with the reply please accept
How do I rest the Service indicator for a 2005 CLK Cabriolet? None of the suggestions listed below worked for me.
First make sure all of the doors, hood, trunk, etc are closed.
Turn the key to position 1
Press system select button(lower left buttons on the steering wheel) that looks like sheets of paper until you see mileage reading or temperature displayed.
Press the brightness button on the lower left instrument cluster 3 times. You should hear a signal and see voltage on the display.
Turn the key to position 2
Press the lower scroll forward/back button(steering left arrows)). You should see "service indicator" on the screen
Press the Brightness button again once. You should see oil type on the screen.
Select the oil grade you used by pressing the + & - buttons on the upper right on the steering wheel.
Press the scroll forward/backward button to confirm. Confirm oil reset, press R(brightness button on lower left on cluster) for 3 seconds should appear on the display.
Service confirmed should appear on the display.
Press the upper forward/backward button & "service indicator" appears on the display.
Press the upper system select button(lower left steering wheel button on left) The display should go back to basic mileage or temperature.
If all else fails. I believe the shortcut I took as a tech was, turn the key to the first position, scroll until you see the temperature or mileage displayed. Turn the key off, push in the brightness button and HOLD it while turning the key to the 2nd position. You should see something like do you want to reset service? press R(brightness) button for 3 seconds and it should reset.
Good luck. The newer cars are worse.
Oct 10, 2013 | Mercedes-Benz CLK Cars & Trucks
Auto print head alignment wont work and I need to do a manual alignment. How do I do this for a MP970?
1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette. 2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension. 3. Press the Paper Feed Switch to select the paper source where you have loaded paper. 4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
5. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
6. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
7. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
Mar 01, 2011 | Office Equipment & Supplies
Dont no how to unlock my galaxy 5 samsung mobile phone it has a email login tryed my email account and didnt work
hi,
try this one ,i hope it will works on you..
1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and
reinsert it
2. Hold the Volume Down button
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage,
and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If the above procedures doesn't work, use this second method below,
1. Shut Down Samsung I9000 Galaxy S
2. Now press the Volume up, Home and Power button together.
3. When Samsung Symbol shows up release the power.
4. Then there is a boot Menu. Use the volume up/down to choose and home to select.
If YES is selected, all data including third-party applications will be deleted from your
Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory
fresh state.
Feb 18, 2011 | Samsung Galaxy S GTI9000 Smartphone
The third select button will not stop down
I have a model 464 and my problem was similar but mine was the second digit.
I replaced the p c board in the selection control box and my problem was gone.
I would check the selection control box.
Hope this helps
Dec 14, 2009 | Nostalgia Electrics Classic Music Jukebox...
Ps3 when i turn it on has a yellow screen and wont load games
Try this:
Turn the console to stand by, you can do this by pressing the power button for 10 seconds.
When it is on stand by (a solid red light shows) hold the power button for 3 beeps, remove your fingers on the third beep which should be a double beep.
This should take you to reset your console. You should see 6 options. Select option 2 then the system will go blank. Repeat the above but this time select option 3.
Your PS3 should work after. Good Luck!
Sep 29, 2009 | Sony Playstation 3 (PS3) Console
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Lost owners manual and need to program remote to Panasonic
HRMC 15 Code Scanning method...
1.Press TV device button on the HMRC 15
2. Press Select and Mute simultaneously until TV device button flashes.
3. TV device Button should now stay lit.
4. Aim Remote at TV
5. Press The CHANNEL button UP ...repeat until your TV turns off.
6. Press Power Button to turn TV back on (Thus confirming you found the right code).
7. Press the TV device button to lock in code.
8. ENJOY !!!
Oct 22, 2007 | Hughes HRMC11 Remote Control
78 people viewed this question
 Grubhead
Grubhead
