GE 103734 3-Crock Round Slow Cooker Logo
Needs replacement cover holder for above product model...blk plastic piece that holds covers
Keeps coming up E4Pressure cooker
Here is a piece from someone who had the same E4 error problem:
I had this problem. I noticed that steam was coming out almost immediately and the cooker would not start counting down. Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle. The plastic cover was so far down on the metal piece that it would not allow the metal cylinder to seat on the vent. You can use the metal piece by itself or work the plastic cap up far enough so that the metal piece seats on the vent in the closed position. I have had no more problems - it works fine. good luck! kc
I love the crockpot but the "plastic" handle broke
Check ebay. Sometimes they have glass covers for some models.
1helpful
I have a 6 qt. Corningwear crock pot, model no. SC-5044 120VAC 34W. I dropped the glass cover on a tile floor and it broke into many small pieces. Is it possible to replace the glass cover, and if...
I need a new crock for my corning ware slow cooker model#SC-5044. I have been redirected to link after link. I just wanna pay for a crock and have it arrive at my door. Could it be that easy or should I have to buy a whole new slow cooker??
2helpful
3answers
Dropped and broke cover for Rival crockpot model SCV401 need a replacement cover.
Rival Glass Crock-Pot Lid Oval
Fits Rival Crock-Pots using a solid oval glass lid cover
Lid Measures approximately 12-1/4" x 9-5/8" from end to end
Lid is glass with a metal rim
If this sounds like it click on the web link below
http://buyitnow64.stores.yahoo.net/ricrpotslcog2.html
OR IT COULD BE THIS ONE
Rival Crock Pot Slow Cooker Replacement Round Glass Lid Cover
Works with Rival Crock Pot Models:
3300, 3302, 3305, 3351, 3350, 3355, 3504, 3520, 3550, 3500, 3654, 3656, 3760, 3845, 3850, 3950
Approximate total diameter: 10"
Use model number NOT measurements for the correct replacement part
PLEASE NOTE: If your model number has a slash or a hyphen and another number on the end of the numbers above (ex. 3300/2), then this lid will NOT work.
If it sounds like this one click on the weblink below
http://buyitnow64.stores.yahoo.net/ricrpotlidre2.html
Hope this may help.
3helpful
3answers
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Hamilton Beach Meal Maker 33675
Called the toll free number for the company and ordered a replacement cover.
4helpful
3answers
Need plastic handle on Rival Crockpot lid.
I am Jo Anne Gomez who posted original problem and thought the problem was resolved with husband putting on a knob he found at the hardware store. Just wanted to let you all know that the handle we thought would solve the problem DID NOT....after he replaced the knob and we did another roast in it the lid totally shattered after we'd cooked another roast (luckily the glass did not get into the food), however, this is just a BAD PROBLEM and these lids should ALL be recalled. I have seen, just recently, the exact same crock pot and lid being sold for much less. I think that these crock pots should not even be sold but taken off the market to prevent lawsuits or horrible problems. Just wanted to let you know our solution did not work and Rival was not helpful at all.
Rival Crock Pot Travel locks
I used two pieces of light bungy cord from ACE Hardware and made loops to go from the handles on the crock then around the handle on the top. They stretch so you can't break the cover or crack or mar any surfaces. I made some longer ones for my NESCO. Works like a charm.
Top GE Crock Pots & Slow Cookers Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a GE Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
