Question about Whirlpool LEQ8000JQ Electric Dryer
A sock fell in the vent of my whirlpool dryer
    President:
  • 1,273 Answers
If you mean the lint trap, try this: Unplug the dryer. With a dryer brush (~$10.00 @ Lowe's/similar), bend to approximate the curvature of your cavity and try to retrieve. If this doesn't work, slide/scoot the dryer out and remove the venting duct. Carry outside and dump. If no sock there, look into the dryer exhaust (where the duct connects). Use the brush again to retrieve said sock (and generally clean as you go, as it never hurts). Also look at your vent where your dryer exhaust passes through the wall, clean as you go..... This should get you back up and running.
Regards, --W/D--
Posted on Jul 17, 2009
How do I remove a sock that fell through the lint trap?
How To Fix Dryer Lint Trap Problems (Removing Items That ...
? 5:32
https://www.youtube.com/watch?v=Fcw1aPqGiSI
Feb 4, 2015 - Uploaded by UKaToNeN
Have you ever had something fall down into the lint trap on your dryer? It`s happened to more folks than you ...
how do I get sock out of lint filter shoot of electric dryer ...
www.shopyourway.com > Manage My Life > Questions
I'm sorry to hear that a sock fell into your lint screen chute and I would like to assist you. Be sure to unplug the dryer prior to servicing it! Do not run the dryer until you are able to remove the sock! There are two ways to do this.
Nov 29, 2015 | Electrolux Dryers
Ihave a whirlpool gas dryer and my wife droped a sock into the hole where the filter is. Made some noise and then seemed to work just fine. Where did the sock go and shoukd I be worried? Thank you
the sock ended up down below at the bottom where the vent fan blows, I would remove the back of the machine,, remove the vent housing inside, and you'll see the fan which runs off the back of the motor,, ( and probably the sock) and remove it , and any other debris thats collected there, Its a fairly simple task
May 26, 2011 | Whirlpool CGE2791KQ Gas Commercial Dryer
I have a whirlpool awz3413 dryer that gets very very hot...its never done this before...any ideas....thanks
Dryer Running Hot
Check and clean, if necessary the vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off.
If you are running too hot you are not moving enough air thru the system. It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Free Answer...Please take time to rate me.
May 16, 2011 | Whirlpool ET8CHEXSQ Dryer
A sock fell in the vent when i was cl/ eaning the lint off the screen. What do I do
Some options:
-- Try to fish it out with a coat hanger with a crook on the end.
-- Buy a tool from Pep Boys (or the like) made for picking up bolts in hard to get places -- it has "grabbers" on the end of a flexible cable -- the grabbers are manipulated by a button on the top end of the cable.
-- Remove the back of the washer and take the vent housing off (a total last resort).
-- There are other options but mostly similar to above concepts.
Charlie
Feb 10, 2011 | Whirlpool Dryers
A small sock fell into the dryer lint trap. How can I get it out?\r\nThank you! Jan
You can try using a metal hanger to hook it and pull it out, but be sure to unplug the dryer before you try. There is also a small pick-up tool about 2 feet long you can buy at hardware stores for picking up small items in tight places. Good luck fishing!
May 18, 2010 | Whirlpool LER4634J Electric Dryer
ITS MODEL number ler4634pqo
take a clothes hanger and try and remove it
Apr 21, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Takes extra time to dry the clothes.
You may need to clean out your lint trap. Not just the part that you pull out. I'm talking about the entire tunnel. Even though we empty the lint trap regularly there's a lot that gets left behind and over time can become a fire hazard. Your arms and hands cannot reach everywhere in there. For this you can attach an old sock or rag to a coat hanger that has been opened up. Go down in there a couple of times with it. You'll be surprised at how much stuff comes out. To further help this problem you can also pull dryer out and check that the vent hose in back is clear and free of debris. Cleaning the trap screen (the part you pull out to empty the lint) with HOT water occasionally will also clear residue that has built up from using dryer sheets. Over time that residue will make those tiny screen holes smaller & smaller & smaller. All of this can affect your dryer's performance.
I hope this info was helpful to you. Good luck!
Jan 29, 2010 | Whirlpool GEW9250 Electric Dryer
Sock fell down lint vent and daughter turned on dryer
Turn off you power to the dryer and then,
You could run a coat hanger straightened out with a hook bent on the end of it into the lint vent at try to hook the sock.
But probably you will have to remove the back to follow the lint vent.
You may try to remove the vent hose and run the straightened coat hanger in there to try and remove the sock.
Hope this helps
Sep 30, 2009 | Whirlpool LEQ8000JQ Electric Dryer
A sock fell into the lint resevoir; how do I remove it?
If your dryer is the model you have this listed under (lint filter on the top panel), then retrieving something stuck in the vent is pretty simple. Just follow these steps:
1. Unplug the dryer and remove the back panel. The dryer exhaust vent is located on the left hand side (as viewed from the rear).
2. Remove the screws that hold the vent in place and remove. NOTE: Make sure you remove the two screws located on the top panel as well. The entire exhaust vent will come out.
If this is not how your dryer is configured, please post back with your correct model number. If you have any questions, please let me know. I hope this helps you.
Mar 31, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
320 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
