Question about Samsung Digimax A503 Digital Camera
Camera Froze I somehow managed to hit the shutter button or something and it has totally frozen up the camera...this happened once before and I have no clue how I fixed it. Help????
    Problem Solver:
  • 9 Answers
Maybe remove the batteries and try to turn it on .. than let it sit most of the day.-4 hours.. Then put the batteries back in and try to turn it back on.. Also check the lens cover and make sure its not stock...
Posted on Jul 17, 2009
What would cause the shutter button hard to press?
I have the same problem. The button feels like it won't press. Then as you give it more force, it suddenly goes. After that the camera works normally for the rest of the session. If I leave it sitting for a few minutes or so, the button somehow 'resets' to this frozen position. Again, forcing the button frees it and it works fine again until you put it away and try again later. Very strange!!!
Feb 10, 2011 | Panasonic Lumix DMC-FZ20 Digital Camera
HAVE NIKON D40 THE LARGE MONITOR AT BACK OF CAMERA HAS BEEN TURNED OFF SOMEHOW HOW DO I TURN BAK ON????
turn on your camera
press the menu button on the back og the camera
using the switch to the left of the screen, hit the left side once to move the screen cursor to the small icon on the left of the menu screen that looks like a "penci".
now click the button to move the highlight back to the right side then move up or down to select "07" Image Review.
hit the 4 way button on the right side to show the two options, on or off.
move the highlight up or down to select the one you want (assuming you want "on"), then press the center of the 4way button, "OK". now when you shoot a picture it will show up on the back screen until you touch the shutter release button again.
Dec 27, 2010 | Nikon D40x Digital Camera
My iphone 4 camera has a frozen shutter problem
This shutter problem could possibly a cause of something that has corrupted the software. For a quick fix try the following: Double tap the home button. Then hold in any of the icons that have come up in the multitasking section at the bottom of the screen. Once the x buttons appear you need to kill the camera app. If this doesn't solve your problem and software restore or update via iTunes should resolve your issue.
Dec 26, 2010 | Apple iPhone Smartphone
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Oct 31, 2010 | Nikon D40x Digital Camera
Overexposed photos??
The view finder "going black" on an SLR is caused by the mirror being up, which is also when the camera is actually taking the picture! The mirror sends the light from the lens to either the viewfinder or the sensor. When it's down, the light goes to the viewfinder and you can compose the picture. When you press the shutter release, the mirror comes up, and light goes to the sensor. In a film SLR, there was a shutter just in front of the film that controlled the amount of light that hit the film. In your D80, it's a combination of the mirror and the electronics that set "shutter speed".
What is happening when you get these white pictures is that somehow your settings are holding the mirror open far longer than it should be open. When you turn off the camera, it drops the mirror automatically. If you are in S or M, it's because you've set your shutter speed improperly. If it's doing this in Auto mode, then there may be a problem with the exposure meter or the lens.
If you describe more about when it happens (shutter speed settings, Auto or manual mode) I can probably tell you if it's your settings or the camera/lens.
Aug 26, 2009 | Nikon D80 Digital Camera with 18-135mm...
Everything works....but hit shutter button & it goes dead.
Hold the power button in the ON position for 10 seconds, then release (obviously making sure the batteries are in first). This forces the camera to do a full reset - you will have to set the time etc when it restarts.
Hope this helps, it worked for me...
Nov 23, 2008 | HP Photosmart R707 Digital Camera
Optio s6 frozen
By recharging the battery, and then restart the camera, it may just work.
Because you were working on a movie in the camera at the time it quit, that file may be corrupted.
It would be interesting to see what has happened on this problem.
Jul 22, 2008 | Pentax Optio M20 Digital Camera
Panasonic Lumix DMC FZ20
Did You try checking the sd card or turning it on and off
Nov 20, 2017 | Panasonic Lumix DMC-FZ20 Digital Camera
Shutter won't depress, advance lever won't move.
how did you fix this i have the same issue
Oct 30, 2007 | Nikon FM10 35mm SLR Camera
Camera shuts off when you click the shutter button
The same thing happened to mine. While not a solution, my workaround has been to turn the LCD screen off when I'm shooting. It's worked so far.
Jul 21, 2007 | Fuji FinePix 2650 Digital Camera
Samsung Digimax A503 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
