Question about Microsoft Internet Explorer 8
Background color problem
Tool bar back ground is black
  • 83 Answers
Try the below settings; make sure that Enable Transparency radio button is checked and the Color intensity is not full.
Posted on Jul 18, 2009
Background on all white pages copies are gray
check printer settings or document settings back ground color settings
you can print a page color to any of the color bar settings so there is a setting that has been change to grey that is causing the problem
Dec 11, 2015 | Epson Stylus NX400 InkJet Printer
My incoming service has two insulated and one bare wire, i'm not sure where to connect them
the BLACK wire is your hot wire that goes to the breaker, the WHITE wire is your neutral bar connector & yes your bare [brass color] wire is your ground only. always use insulated tools when making any electrical conections. be safe.
Nov 25, 2011 | Cutler Hammer 100 Amp Main Breaker...
Scanner reads some barcodes (black and white, larger barcodes), but not smaller barcodes that are black w/gold background.
Acutually, some kind of conbinations of bar color and background color will prevent barcode readers from accurate scanning. So I think you should check whether your color combination is feasible first.
I want to attach an image, but it is too big to upload.
Feb 08, 2011 | Intermec CK31 Barcode Scanner
How to change back ground color of an image?
Too many varibles ,but I'll give it a try. are there any layers? does the background layer ( the one called background at the bottom of the list in the LAyers palettte) have anything in it? area all the visible layers above the "background" transparent where they are "white"? If this is the case it's much easier than if any of the layers are "white" or some other color- then you need to select out the items you want not to change color, using any number of the available "selection" tools, from the area you want to change color- now that can be a challenge.
Jun 02, 2010 | Adobe Photoshop CS2 for PC
Tool bar changing its back ground color
Click on Start, Go to Control Panel and click on Personalization, there you will be able to change it back to the color you like.
May 29, 2010 | Computers & Internet
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
My desktop back ground show some time white color and some time black?
Right Click on the desktop background and go to properties. On the desktop tab there is an option to change the color of the desktop background.
Thanks
Kindly rate the answer
Smith
Jul 08, 2009 | Acer Aspire (AST180-US340B) PC Desktop
The backlight is black i can mouse and click on documents plz hel
can you see the task bar?
try moving the LCD panel open and cosed and see if there is a short in the LCD ?
to change the back ground .. right click the background and select properties ...select the desktop tab and check if the background option is set to none ...and change it to be something else you like
Mar 25, 2009 | Acer Aspire 4315 Notebook
Black Background Around Layer Window
The expanded area outside your document is called the "workspace". You can change this to any color you want by following these steps:
1) Select the color you want, this will make the selected color into your Foreground color swatch.
2) In the tool palette select the Paint Bucket tool (this tool shares the same space in the tool palette as the gradient tool).
3) Make sure your window is large enough for you to see the workspace.
4) Hold down the Shift key and at the same time click the paint bucket in the workspace.
This will change the color of the workspace to the color you chose as your foreground color in step 1.
Dec 26, 2008 | Adobe Photoshop CS2 for PC
How to change background in a picture
first you click on file >open (then choose what you want to back ground color) Then opwn the picture you want cut with any tool like lasso tool and click drag on background windows. it works
Sep 21, 2008 | Adobe Photoshop CS for PC
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
