Question about Kitchen Ranges
Element burned and popped and now the oven doesn't go abouve 175 degrees. Just the top element works for pre-heat.
    President:
  • 512 Answers
Replace element. It went bad. Easy to fix and around 15-40 dollers depending on model.
Posted on Jul 17, 2009
When baking when oven gets to temperature, and you open the door to put food in The grill comes on and burns everything. I use the middle of the oven, but it still happens. Any suggestions.
Not sure how your oven works, but older ones had a "pre-heat" setting that you would use to get the oven to temp. This ran both the upper (broiler/grill) and lower elements at the same time to raise the heat quickly to temp. Once the oven is pre-heated, you would switch the selector to "bake" and that would only allow the lower element to work after that. If you failed to remove it from "pre-heat", it would use both and burn the food. Just saying.
Sep 02, 2016 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
My new oven doesnot cook lasagna through evenly.
Hi Angela,
There are many different possibilities that can cause this issue. From a faulty thermostat, to placement of the food in the oven, or not giving the oven enough time to pre-heat before placing your food item in the oven to be cooked. I have found that on many ovens they can reach well over 450 degrees during the pre-heating cycle. I had a customer who called because her new oven was burning her brownies on the outside and they were not done on the inside. The customer told me that she would wait for the pre-heat signal beep(oven is ready) before putting the tray of brownies in the oven. When I initially checked the oven tempature using a fluke meter and a thermocouple at the center of the oven I found that the oven was close to 460 degrees when the beep went on to indicate the oven is ready! So that is why she was burning her brownies. It took another 10 minutes after that for the oven to stabalize and keep the tempature at 350. So you might want to give your oven 20 or 30 minutes of pre-heating time before you put your tray of Lasagna in the oven. Always make sure to place the food item at the center most part of the oven. And if you are cooking several trays make sure to stagger their position on each rack so they are not right above/below each other. The positioning is important because it can interrupt the natural flow of heat in the oven. So if you let it pre-heat for a half hour and are still having the burning issue then you should have the oven tested for proper calibration to make sure the thermostat is working properly.
Mar 10, 2010 | Garland H283 Gas Kitchen Range
Oven will not heat until you turn the heat up to 400 degrees
Your "Bake" element may not be working properly. It's the one in the bottom of the oven. Place a couple drops of vegetable oil on the bottom pan, and turn the oven on. During pre-heat, you should start to see those oil drops generate some smoke, IF the lower element is working properly. If it isn't - voila'.!! Problem is with the lower element / associated circuit.
Oct 02, 2009 | Amana AOCS3040SS Electric Single Oven
Oven heats, but does not get to correct temperature as fast as it did, lower oven heats OK . When the pre-heat time is complete, oven was still 100 degrees less than designated.
when you first turn it on both elements should come on(your top element may be burned out)if so turn breakers off just take out the screws on the mounting plate pull out and take wires off and replace
Aug 25, 2009 | Ovens
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Oven does not heat up beyond 240 degrees, which takes a long time
You have either a burned our lower element or a wire has burned off at the terminal for that element. The good news is that the lower element is cheaper.
Jan 28, 2009 | Kenmore 47783 Electric Single Oven
Heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
