Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
I have a motorola mts2000 and it just started having sound come from both the earpiece and the mic. I have tried several different commports and mics and it still has not fixed the problem.
  • eradiostore
    eradiostore May 11, 2010
    Could you better describe the sound? Is it white noise as in squelching? Or is it more of a motorboat sound?
  • 27 Answers
Try this,
Remove the battery, let the radio sit for about 5 minutes. Replace the battery WITH the mic attatched to the radio and turn the radio on.
Hope this helps, Bill,
Posted on Aug 24, 2009
Why does my volume not return to normal levels after using a motorola headset? Is there a way to return the unit to factory settings?
the volume control for the headset is typically the same one you use for the phone. plug the headset in again & use the volume control to increase/decrease volume as you require, remove the headset and use the same volume control to increase/decrease the volume on the device..
Nov 12, 2014 | Motorola Talkabout MT352R Two-way Radios,...
Motorola T5725 - Earpiece with mic wont work
A few things you might check:
1) Be certain the radio is turned off when plugging in any audio device.
2) Be certain the device is plugged in all the way. You should feel it seat, or click into place.
3) Use a device designed for your model radio. Aftermarket accessories don't always have the functionality of the OEM device.
4) Be certain you have special features such as VOX turned off on your radio.
Hope one of these helps.
Best regards.
Mar 27, 2013 | Motorola Talkabout T5420 (14 Channels)...
Hooked up to Motorola I680 receiver has echo when he talkes
its probably feeding back (the mic is picking up the sound from the earpiece) try lowering the volume and see if that helps reduce or sole the problem
Oct 10, 2010 | Motorola Mobility H680 - Headset -...
Hello i am trying to pair my lg rumor with a
try holding the button and pulling the mic down after 2 secs
Jul 18, 2010 | Motorola Mobility H500 Wireless Headset
How do i connect my motorola n136 earpiece to my laptop. Its a Toshiba Sattelite, I broke my mic port, and want to know if i can use my bluetooth earpiece for my mic instead.
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>>>>>>>>
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Jul 11, 2009 | Motorola Mobility HS850 Consumer Headset
Bad transmission
Troubleshooting ideas:
1) Try the radio without the remote speaker mic (RSM) attached. Do you still have the same issue?
2) Check the RSM's mic area for dirt/debris or something covering the hole. It is usually in the lower corner of the grill area of the mic.
3) Try someone else's RSM on your radio and see if the problem is still there.
4) Check your battery. An old or defective battery will cause transmit issues. Try a known-good battery from another radio to see.
5) If all of the above are addressed and you still have an issue, you may be experiencing low transmit power, and your radio would need to be serviced.
Mar 22, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
I evidently dropped my Motorola H700 Earpiece and lost Mic Cover
as far as I know yu have to buy a new one but if you do find out that you can just buy the mic. please let me know
Dec 08, 2008 | Motorola Mobility H700 Wireless Headset
Ht1000
This unit is in need of repair.
Jul 15, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
HT1000 repair
Check the battery contacts for any dust or corrotion.
Nov 21, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
122 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
