Question about Thetford Refrigerators
I have a 2007 camper with a norcold n61x fridge and only the frezzer gets cold
  • 159 Answers
SOURCE: Norcold model number N621 won't power on
its difficult to explain the dc are going to the thermostat and from the thermostat to a element that warms the outside to make cold in the inside does it have a pc board or not be free to ask questions
Posted on Jun 01, 2009
  • 9 Answers
SOURCE: fridge not cold
i have had this same problem. Pull the back cover in the freezer off. If there is a bunch of ice on the coil change to heating element.
Posted on Jul 05, 2009
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
  • 68 Answers
SOURCE: fridge wont get cold with gas
This is worth a try. Disconect the gas and power make sure the pilot light is out. Turn the fidge unside down overnight then unright again. Try it on gas agian. This worth a couple of goes before giving up.
Posted on Aug 30, 2009
  • 323 Answers
SOURCE: The fridge is not getting cold, frezzer is working
unplug unit and let defrost overnight, use a blow dryer to speed things up if you like , return air ducts are iced up by the evaporator coil,
Posted on Nov 07, 2009
Why does my Norcold fridge on Jayco 2014 come on but does not get cold?
if chimney cold check heater element and LP for flame if chimney hot unplug thermistor from control board let run if gets cold replace if not either bad board or cooling unit
May 16, 2014 | Thetford Norcold RV Cooler/Freezer
Norcold fridge for my fifth wheel is not working leveled camper still nothing 115 v going to fridge on auto setting
How old?
Jan 03, 2013 | Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My norcold N841 will not cool on AC or Gas it has power and the gas will fire up
Most of the time if the unit has lost a/c gas and 12 volts which puts the unit into a defrost mode so there is a simple reset that can be preformed by unplugging the a/c cord from the back of the fridge and the 12 power going into the control box. leave them disconnected for about 15 mins and then reconnect them in the reverse order and check the inside frezzer at the back and fins on the rightside of the inside of the fridge to see if the unit gets cold
Sep 02, 2009 | Refrigerators
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Sep 01, 2009 | Refrigerators
Fridge wont get cold with gas
Aug 30, 2009 | Thetford Norcold N323 1.7-cu ft 3-way...
May 26, 2009 | Refrigerators
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Refrigerators Logo
181 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
