Question about Cameras
The memory card release want reset after removing the card. It stays out and wantlock back into place on my Maxxum 5D Camera.
    Problem Solver:
  • 9 Answers
Did some one put the card in wrong..?? there is a small plastic pin that grabs the memory card and holds it in place... if its broke its tear the camera apart and replace...it ouch
Posted on Jul 17, 2009
Memory card will not go in all the way and the door won't shut.
was it working before?
turn the memory card anyway and have a try - before check inside the memory card compartment with a flashlight if you can see the contacts at the bottom and insert the card corresponding to them.
Or try another card to exclude yours is not damaged or wrong type somehow....
Konica Minolta MAXXUM 5D Instruction Manual Inserting And Changing Memory...
Mar 07, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
Trouble installing the memory card.
Is this the original memory card? if not! and you recently bought one card, sounds like the right configuration but it is a bit to long for the camera body. I suggest taking it to a camera shop to make sure it is the right card.
Mar 30, 2012 | Konica Minolta Dynax 5D / Maxxum 5D Body...
I can't find the driver(s) for a Konica Minolta Maxxum 5D Canera. I found one for Windows 95/98 but it will not work with the Vista 32 bit Home Premium Operating System.
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Mar 14, 2011 | Konica Minolta Dynax 5D / Maxxum 5D...
Hi, the flash card card-eject lever spring is broken and wont eject the card. u have to manually push the card in place and pull the card out. the lever stays up until u shut the card slot door.once the...
I have the same problemI think that the reason that the not record the image is that the card slot door is pushing down on the card eject lever and ejecting the card when the door is closedThe only answer I can think of is to shorten the leverdavidh
Feb 18, 2011 | Konica Minolta Dynax 5D / Maxxum 5D Body...
No images show up on screen after shutter releases
If the images are recorded on the card but not shown immediatly after the shutter release, press MENU, go with the control dial to the recording menu (the one symbolised with a camera) and press AF, the center knob.
On page 1, the third item controls the instant playback, it can be set to OFF, probably your setup, 2, 5 or 10 seconds.
Oct 21, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Need to set self timer
Press the MENU button, select "Drive Mode," then select the self-timer (one-handed clock). To start the self-timer, press the shutter release button.
Sep 06, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Can't format memory card on maxxum 5D
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 09, 2008 | Konica Minolta Dynax 5D / Maxxum 5D Body...
    Minolta Maxxum 5D
    The P-channel MOSFET switching the CF power is dead. It is on the little board directly above the battery compartment. SOT23 package, the marking is 338 or something like that. Replace it and it will work.
    Mar 04, 2008 | Konica Minolta Dynax 5D / Maxxum 5D...
    Camera makes noise when switched on and shutter won't release.
    This is a job for a repair shop - though be warned it can be pricey and may even have to be junked -So you are in for an expensive time.
    May 21, 2007 | Konica Minolta Dynax 5D / Maxxum 5D...
    Camera freezes after taking picture
    Shooting in the dark here, but the basic things you should try before all else is another mem card, and new compatible batteries. sounds more like a card problem though. hope it works out
    May 12, 2006 | Konica Minolta Dynax 5D / Maxxum 5D...
    Cameras Logo
    54 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
