Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Tv goes off, then comes on, and volume goes to max
This past weekend my mitsubishi hd1080 started acting up. This only occurs when on cable Verizion Fios. Does not occur when watching DVD or VCR. Does not occur all the time. Verzion techs are stump. The tv does no turn off nor the cable box.
the error message i recieve is this " check connections or power the connections for RGBHV or YPrPb be invalid."
it acts like the tv loses signal with the cable topbox dvr.
the screen flickers, goes black, the picture comes back on and gives error message.
when this happens i lose control of the remotes cable and tv i must push the a/v reset on the front of tv. once pressed the remote works.
i watched the Tv all day never occurred until verizion tech came. he changed set topbox. Still occurred. he called another tech and he suggested changing to a newer model set top box. once he left it started again. occured more often about 20 times in a 5 minute period if not more.
i left for a while came back and turned it on and been fine. any suggest much appreciated.
  • Mitsubishi Master
  • 3,866 Answers
OMG! Verizon Fios at it again with changing boxes! Well let me tell you if you do not loose signal on a DVD using these same inputs ITS NOT YOUR TV!
Whats going on is further into Verizon system you loosing the signal from the VDSL slam outside in the pill box. This thing will need to be replaced and they are going to blame your TV until you just give up and buy a new TV only to figure out its not your TV.
1. Call them back
2. tell them to check there network
3. if that dont work tell them to check it again
4. if you have HDMI use that instead of the scart connections.
I hope you have luck with Verizon Fios there internet rules but there TV service is sub par!
Thanks
rulds2008
Posted on Jul 17, 2009
My Mitsubishi hd1080 tv will not come on when i turn the power button on the green timer light comes on but the tv goes back off
The TV reset may help you. If the timer was set by accident many of these TV's that have the sleep timer have this problem. Try the factory reset initialization.
Nov 19, 2014 | Televison & Video
Have a Mitsubishi TV wd60735 the tv volume just increases to max by itself, sometimes won't turn on, sometimes no remotes will work it and I have to pull the plug to reset it to get it to come on, have it...
Sounds like your tact switches on the front of the TV are shorting out. Unplug the plug for the switches. if the problem goes away then try to clean the switches with rubbing alcohol, if still has problem replace switches.
Aug 27, 2010 | Mitsubishi WD-60735 Projection Television
I have a Mitsubishi HD1080 TV with a fog over the picture
CRT needed coolant replacement.Try Tv repair World.com to buy coolant and a CD instructions for replacement.
Feb 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi HD1080 Ser.#Wf65809 It has worked fine until this week when DirectTV hooked-up their satellite dish and programmed the tv. When the tv is turned-on e the picture is great for about 6-7...
It may be an internal filter on the tuner board or in the cable line. Otherwise it may be a firmware problem that is causing this. Make sure tv is set for CABLE and not AIR
Sep 09, 2009 | Televison & Video
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Mitsubishi HD1080
I will need to know your model number in orderto help you locate a PC board for it.
Jun 15, 2008 | Televison & Video
Power Problem
Most likely the power supply is failing, or some other circuit that is causing a safety shutdown.
Without doing the proper tests and diagnistics, it is impossible to accurately speculate the exact fault.
Jerry G.
Jun 01, 2008 | Mitsubishi WS-65819 TV
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi 1080 72in diamond seris
52" mitsubishi 1080p t.v. warning shows up on screen AIR FLOW IS BLOCKED. Check owners guide and they don't tell you how to clean it or where it si at.
Aug 29, 2007 | RCA F38310 38" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
209 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
