Question about NAD T973 Amplifier
Grounding noise I purchased me t973 a little over a year ago, and use it very seldom. Then one morning I turned it on and heard a grounding sound in all speakers. I disconnected everything else (including the T-163 pre-amp), leaving only the amp and speakers. I still hear the grounding sound. I also notice that one of the 3 fans at the bottom isn't spinning.
    Problem Solver:
  • 4 Answers
The problem with the NAD T973 power amplifiers are usally located on the power supply board.
If inspected you may notice swelling of the high value large electrolytic capacitors. In particular the 22,000uf and the 15,000uf caps.
The other filter caps such as 1000uf and 470uf as well as 3,900uf can also be faulty.
I have had this very problem and found it to be a result of the 1000uf caps specifically creating the loud humming although all amps still were working well. After their replacement, all was well again.
I have also come across the high value caps failing in these amplifiers after around 6 years of age, so would recomend replacing all the mentioned values above if near this age or older amplifier is being serviced.
NOTE: High quality and high temperature capacitors only should be used as repalcements. Mylar manufacture such items although there usally is a fair modification required to fit the 22000uf caps as they are much larger than the NAD originals but they exceed their quality.
Posted on Jul 28, 2009
  • 54 Answers
Pull bottom panel and get some canned air and spray around circuit board .May have a shorted capacitor to ground.Might have to use repair directory on this site.
Posted on Dec 01, 2007
BOSE Solo will not turn on and when it does 50% of the time it produce a "ground noise" sound.
Wall plug--get a two prong into wall socket-- the front has the holes for three prongs also a little eye you can connect a wire to and screw into the screw on the socket plate
Oct 08, 2016 | Bose Solo TV sound system - Black
Toshiba MK1059GSM sudden noise?
First backup all your data asap. Noises of this type are a sign of a failing drive.
Then run the extended test... http://gsmartcontrol.berlios.de/home/index.php/en/Home
You should be able to replace the drive with in the one year warranty period.
Sep 12, 2012 | Toshiba (MK1059GSM) 1 TB Hard Drive
On my mod.#BBQ075 Ser.#20149, The lighter probe will not heat up to lite the pellets. I unscrewed the switch panel and found that the 3amp fuse was blown so I replaced it with the one provided. It...
It sounds like you have a short somewhere. I would recommend that you check the ground wire to make sure that it is secure and grounding properly. It sounds like it has lost contact, or either you have a loose wire that is grounding out and that is what is causing the fuse to blow.
Mar 06, 2011 | Traeger Industries BBQ075 All-in-One Grill...
Grounding noise during washing cycle. Maytag washer
Hi, Check your motor coupling, it is between the motor and transmission,made of rubber and plastic, if it is not broken and you heard a lot of screaching ,i would say it is your basket drive tube-could have gotten worn down on the bottom around the clutch brake area! Better purchase a used basket drive tube,install it with a new clutch and it will start working for you.
Apr 12, 2010 | Maytag PAV2300 Top Load Washer
Subwoofer popping noise
i had an amp do that a few years ago i did everything it turned out that it was the cdplayer. then agin myfriend had the problem and it was his altonator he had to get a ground loop isolator they are cheap
Feb 02, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Ilo 42" lcd flatscreen loud grounding sound
you need the main total assy replaced. contact the manufacture for your nearest servicer.
Jan 23, 2009 | iLO 2600 Television
Engine lost power while travelling
old fords never die ,sounds like water pump packed up and as this is driven by the timing belt its stripped the belt and valves hit the pistons ,,,time to retire this lovely car to the motorway in the sky
Dec 24, 2008 | 1998 Ford Escort
Buzzing sound
poor grounding.. loose grounding or replace the wire with with the best quality grounding......
Nov 04, 2007 | Lexicon Lambda Usb Desktop Recording...
Static comes from speakers
I think it's a grounding problem. Actually, it's a necessity for all audio-video equipments to get grounded properly. If you don't have a ground connection in your AC plug, your receiver will collect more and more static electricity. As a matter of fact, it decreases the sound quality that you can get from your equipment. I think that the effect of your reaction (slapping the receiver) isn't coincidental. When you touch any metal surface on your receiver (even while slapping) you condact the static electricity to the ground. I've had a same sort of problem with my receiver. Especially when I connected my laptop computer to the receiver, I heard an annoying distorted sound from the speakers. I found out that it was ground loop, which occurs when the negative (common) signal of the source coincides with the one of the receiver's. As a solution, I grounded my amp, changed all wires with new and shielded ones, and purchased an AC filter. Then, I got rid of the noise. I have to say that the AC filter (Belkin Pure AV Surge Protector, it also includes an AC signal filter)benefited me the most.
May 03, 2007 | Aiwa AV-D67 Receiver
NAD T973 Amplifier Logo
276 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
