SOURCE: how to make philips HTS3565 region free
Region code hack posted by videohelp4k1ng, July 27 2008:
Hack for HTS3050 also worked with my HTS3565D.
Open the tray. Press 99990 on the remote.
Region 0 will appear briefly on the left of the screen.
Region code hack posted by rocky631689, August 01 2008:
Also works on my Philips HTS3568DW/75
THANK YOU!!!!!!!
Region code hack posted by mikoyan, August 05 2008:
I´ve just applied to my HTS3565D/37 and it worked great. Do not expect it to show anything in the display, though. You open the tray, click the sequence in the remote and... Done!
SOURCE: Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
SOURCE: How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
SOURCE: Home Theater philips HTS3372D/F7 change for regio Free
Turn on the player
With the tray open press:
99990 on the remote
Region 0 will appear on the bottom left of the screen
from http://www.videohelp.com/dvdhacks
